cal Options
cal
#1 Posted : 18 October 2014 11:53:54
Morning. ..... ive finally received pack 48 with the missing cooling tube next problem is the reservoir am I been thick or I missing the grooves off the reservoir
cal attached the following image(s):
#2 Posted : 18 October 2014 12:01:38
Grooves?
Do you mean the bands which run around the outside of the tank?
#3 Posted : 18 October 2014 12:15:13
BigGrin Hi Cal
The grooves are or should be on the side of the tank that you are resting the part on to take your pictures
cal
#4 Posted : 18 October 2014 14:49:10
on page 98 or the instrutions it says: After inserting
the tube into the
reservoir, fit the
long parts of the
tube into the
grooves on the
reservoir:where does bracket A attaching to the reservoir is it on the inside or the out side hard to tell on the picture
#5 Posted : 18 October 2014 15:25:32
BigGrin Hi Cal
After putting the tube in the grooves you stick bracket A over the top of the tube to hold it in place, so its a sandwich of tank , tubes and bracket. hope this helps.
This page was generated in 0.123 seconds.
