problems Options
john burgess
#1 Posted : 28 October 2014 11:04:21
Well not off to a good start here, i seem to have the same problem as Foz got a warped ship, Darren (Son of Bullwark) suggested it could be piece 30 so i have checked and it does seem quite a bit higher any ideas shipmates.No use proceding on till i got this issue fixed going out later to get some bits so im gonna pick up some acetone and try and remove the end section.
john burgess attached the following image(s):
If you dont suceed at first go to the pub
#2 Posted : 28 October 2014 12:47:29
Hi John
Have you made sure all the formers are seated all the way down on the false keel as this can cause the type of problem your having.
john burgess
#3 Posted : 28 October 2014 13:04:42
Hi Andy i am not aware that bow sections are not all sitting flat, i want to get some acetone and strip it down a little and take the bottom section of floor away and then re rig it up hats your thoughts ????
#4 Posted : 28 October 2014 17:11:38
Id have to go along with Andy and say to check your formers are all fitted as far as they can into the slots, they may be very tight so you need really push them in. Some more pics might help, perhaps if we can see the bottom of the formers at the false keel. Good luck with it anywayBigGrin
john burgess
#5 Posted : 28 October 2014 17:44:37
managed to get the back part off, sanded it down and retried it and its spot on dohhhh!!!!! silly me didnt have it pushed down properly
#6 Posted : 28 October 2014 18:23:35
Its easy done and quite a few have fallen foul of this. Good to hear its now sorted BigGrin
john burgess
#7 Posted : 28 October 2014 18:31:57
Yep sure was 2 hours with acetone to get it off but was worth it cos i didnt damage anything taking it off, also i am going to jig it up to morrow and make sure everything is spot on, no twists etc etc then i can carry on with the build.
#8 Posted : 28 October 2014 21:25:11
WTG John,Cool Cool
It`s sometimes a steep learning curve, but when you start recognising issues,you learn how to avoid them in the future.
Nice result. BigGrin
#9 Posted : 28 October 2014 22:31:52
So pleased you got this resolved John, very well spotted and well done on resolving the issue.... Cool Cool
#10 Posted : 28 October 2014 23:06:10
BigGrin Great you got it sortedCool
john burgess
#11 Posted : 28 October 2014 23:28:24
Thanks for the kind remarks guys, i guess there will be something else crops up before long lol.
This page was generated in 0.063 seconds.
