With my recent debacle of my zero and considering the actual damage done to it resulting in a restart I decided to review my options for building.
It was clear that the bog standard superglue that I used was effective to a point, but the sheer strength was not. I found that it was possible to pull the thing apart with just normal pressure.
This means to me the following points
1. I did it wrong. 2. I am stronger that I know that I am 3. the glue is just not up to it. 4. I am not up to it and should give up.
After making these points I decided that I should look at just what I may need.
Option 1 welding/TIG kit.
Result: Don't make them small enough! besides, Aluminium melts easily!
Option 2 Rivet the thing together
Result.... we have screw together parts... but trying to use rivets that small? LOL - besides, do they make them that small?
Option 3 glue the thing
Result: Tried that with partial sucess.
Option 4: Ask someone else
Result: Ah ha! now there's a good idea.
So, I duly went online and emailed Loctite Technical services. They are the glue guys and should know more than me. I told them what I was doing and asked what I should use. They emailed me back and said give this a try
Loctite 330 multibond
The word bond, not glue attracted my attention. It seems that this could be the stuff I need to make sure that the frame stays together.
I will give it a try when new parts start turning up!
Anybody else have thoughts????
I use Loctie 496 which is a professional superglue made specifically for bonding metal, also use Loctite superglue gel and Zap thin CA. The three combined work for me..
flippin' heck,don't fancy mixin' them three together!!!!!! Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
 Hi All I have been using Zap 'zap-a-gap' but only when needed and in miniscule amounts as I have found so far that after spraying the ribs and fitting together ect they stay in position without moving. regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Well.
I know that Mr T knows exactly what he is doing (can I have lessons?).
I think that I will try the 330 bond and see what it does!
wow Tomick that locktite 496 is expensive... £21 a bottle. On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Where did you see that price
I buy it trade at a fraction of that cost, and even a quick eBay search throws up £7.12
http://www.ebay.co.uk/it...amp;hash=item2a2685d830
Joined: 10/05/2011 Posts: 204 Points: 631 Location: Morayshire
Thanks for the link Mr T, have bought some. Regards Bob Builds in progress
1/12 Spitfire (Deagostini) 1/8 McLaren (Deagostini) 1/16 Stuka (Hatchete) 1/16 Zero (Deagostini)
Joined: 11/05/2011 Posts: 766 Points: 2,128 Location: Dagenham
My brother bought me glue when he was out the other day it's called UHU. Anyone no if this is ok to use as it says metal on it but I wanna check first CURRENT BUILDS
Mclaren MP4-23 Ford 1/12 Shelby Mustang GT500 2010 HMS Pandora
 Rank: Pro   Groups: Registered, Official Builds Joined: 10/02/2012 Posts: 475 Points: 1,237
I use the Loctite, a product over here called JB Weld which is an epoxy formulated for metal, and Gorilla Impact Tough (a CA with rubber fibers in it) The use of each is situation based. Tired, Old, and Cranky!
So should I buy a different one? CURRENT BUILDS
UHU is quite thick in form and is rubber based i think so it will leave a lumpy mess around the joints and will look unsightly. I have been using medium superglue for my build and have had no problems, just remember to get a good way of applying it spareingly. Here's are a link to give you and idea on applicators, http://forum.model-space....aspx?g=posts&t=9318Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi All, I`ll add my support to the Loctite 496. Not the cheapest, but is cheapest always best? I`m building the "Stuka", which has a brass airframe and it works great. A 20 gram bottle goes an awfully long way as well. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
S2ksean wrote:My brother bought me glue when he was out the other day it's called UHU. Anyone no if this is ok to use as it says metal on it but I wanna check first UHU isn't ideal as its not easy to work with and is very slow bonding. its really a general purpose domestic repair glue you should go for something more purpose formulated. Zap is my fave brand, as Andy says a medium is probably best. I have used a number of different brands over the years for metal and i have to say the Loctite 496, which is formulated for metal is extremely good and only a couple of quid dearer than Zap. 20g goes a long way. as for applicators you can get specie;its applicators these days but i still use a piece of wire in a pin vice. Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Brilliant thanks guy really appreciate it. Il order some today and hopefully make a start soon CURRENT BUILDS
Guest (7)
