Should any issues be constructed ahead of any prior issues? Options
f13dfx
#1 Posted : 12 November 2014 01:16:30
Rank: Amateur Level 2
Red Medal: Red Medal
Hello all!
Just started my personal build of the MP4-23 and I am currently at Issue #59. Taking my time to make sure I don't miss a step.
For those of you that have built this model, I wanted to know if there were any issues which I should build ahead of the sequence.
I know through my read of a lot of the builds there is the fit problem with the outer intake cover fitting flush on the sides. I guess the only cure is a hair dryer to heat up the sides and bend them a little to make the fit.
I'm thoroughly enjoying this build and discovering that this was worth every penny!
Thanks in advance for everyone's help so far!
This page was generated in 0.217 seconds.
