They are actually different compoundsTomick attached the following image(s):
Joined: 05/04/2013 Posts: 540 Points: 1,630 Location: England
Nice! Finished 3D Printer, RB7, Hummer, Skyrider drone & Combat tank collection http://www.model-space.com/gb/
Joined: 03/10/2014 Posts: 40 Points: 109 Location: aberdeen
tomick can we assume u will be doing ur usual superb step by step for the extension packs.is there any news on uk prices yet or ill they be the same as the rest off our packs
Yes, the build will continue with the extension packs.
Joined: 26/05/2014 Posts: 206 Points: 621 Location: Swellendam, RSA
Hi Mr T, am I correct in assuming that we will be getting extra rims as well. This means an extra 8 rims It's not the fall that kills you, it's the sudden stop
Building: Bismark, 2.5m wingspan glider
Yes, 8 rims included and rim decals.
Stages 101-104 are 'medium' tyres with wheels & rim decals.
Stages 105-111 are the two-speed gearbox components.
Stages 112-115 are the 'super soft' tyres with wheels & rim decals.
The yellow tyres already provided are 'soft' grade.
Joined: 05/07/2011 Posts: 126 Points: 354 Location: Withernsea East Yorkshire
Hello all long time no writing lol hope everyone is fine and dandy! So i guess that there is going to be more parts and for us uk subcribers we can buy the full set in one go would it not be better to send them out as per normal so 3 deliveries of 4 parts then the last 1 three parts? just a suggestion Admin any thoughts on this
Cheers
MeffMan :)
Joined: 23/07/2013 Posts: 120 Points: 336 Location: Brisbane Australia
Hi Mr T, Could I just confirm that to fit the 2 speed gear set that there is no changes required to the motor? I'm about to start assembling my motor and don't want to pull it apart if we need to for the attaching the 2 speed gear set. Chasecar
 Rank: Pro  Groups: Joined: 11/04/2013 Posts: 119 Points: 347
you won't need to pull the motor apart to make upgrade to the 2 speed. A new clutch bell is provided with two pinion gears as well as an extended fly wheel nut/clutch shaft to work with the new clutch bell. It's just a matter of changing a few things around with the clutch.
Thanks Rowdy85...good to know Chasecar
Joined: 22/03/2013 Posts: 40 Points: 113 Location: Winsford,Cheshire,UK
Thank you for replying to my post.
Any more news yet on when the Issues will be added to the online shop.
Joined: 21/09/2014 Posts: 2 Points: 9 Location: Mukwonago
This is awesome news. I just started not too long ago and heard about the extentions.
Anymore news on when the full series will be added to the online store.
Joined: 22/08/2013 Posts: 1 Points: 6 Location: townsville QLD Australia
my RB7 is complete just have to do paint work ,got all the extension parts the only thing that cannot be supplied is the binder that was meant to be supplied with the extension issues, contacted supplier ,they say they can't supply and have no idea if they will be able to supply it. so that messes up the whole build as I have all magazines but no binder for them not happy.
The extension is due to go on sale shortly, further detail will be provided at the time of going on sale.
 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,496 Points: 4,400 Location: Essex
What if like me you have just subscribed so won't be needing the extension series for another 2 years, if being offered as a whole pack it might be quite popular as people might want spare tyres and wheels. Could it therefore possibly be sold out come 2 years from now and I won't be able to get the extensions then? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
Best to buy the extension as soon as you can after going on sale., 2yrs down the line there may not be any stock left.
Ok cheers. I'll keep an eye out. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Guest (13)
