Das Schnellboot Options
#1 Posted : 20 November 2014 20:36:58
I have just received the g/f hull and plans from 'Models by Design' for a r/c Schnellboot or E-boat at 1/24 scale making it just over 58 inches long with an 8 and a quarter beam. The hull is one piece and has a very nice finish that will need a minimum of finishing off and is at about the right thickness to get maximum strength to weight, The plans give a good layout of the decks and fittings.A very nice hull and plans set that would be good for the novice or expert to get to grips with an electric and R/C set up
Initial plans will be for a triple screw and rudder set up with independent motor control for each motor and maybe the bow 20mm sweaping from side to side or something like that. There are some unusual camo jobs from the Baltic and Norwegian E-boats that i will be looking at.
#2 Posted : 20 November 2014 20:39:29
#3 Posted : 20 November 2014 21:45:35
Awesome boat, I remember having a a small scale one of these when I was a kid.
#4 Posted : 21 November 2014 10:28:42
Will be a mega build Cool
#5 Posted : 21 November 2014 13:27:02
Looking forward to this 😎😎😎😎😎
β€œWhenever you find yourself on the side of the majority, it is time to pause and reflect.”
#6 Posted : 21 November 2014 20:00:04
BigGrin Thanks everyone for looking in and your commentsCool
#7 Posted : 21 November 2014 23:27:08
Now this should be a great one to follow Andy. Look forward to seeing you get going on this one....Cool Cool
#8 Posted : 22 November 2014 08:14:15
BigGrin Thanks for looking in and your comments AlanCool
Warthog
#9 Posted : 22 November 2014 13:18:34
That's a nice bit of kit! Looking forward to seeing this one come together AndyCool
Spencer
#10 Posted : 23 November 2014 08:34:44
BigGrin Hi Spencer thanks for your comments and looking in Cool
This page was generated in 0.134 seconds.
