Very Bad Customer Service - worst I have ever seen Options
jdwigley
#1 Posted : 21 November 2014 17:23:09
Rank: Newbie
Unfortunately I have had a bad experience with customer service - not about the shipments but about the "free's" that are supposed to come with the 2nd and 4th kits - I worked and called multiple times to get the 1st on (took till after 5th kit) and just called about the one with the 4th kit and I have started to jump through the hoops again to get it - they are saying the same thing as last time about supply chain - no longer trust this company - was going to start 2nt kit but after this will not.Mad
JD
#2 Posted : 21 November 2014 17:29:46
JD
Hi JD, BigGrin
Could you let us know which kit it is you are building, then maybe we can get you a more precise answer as to where the issue of distribution of your required items are.
Kind Regards
jdwigley
#3 Posted : 23 November 2014 15:46:12
Rank: Newbie
Derek - working on the akagi - due kit 6 - J
#4 Posted : 23 November 2014 16:05:20
Hi JD, BigGrin
As with a lot of company`s, Deag are no different as to be reliant on other company`s for supplies, but give me some time to make some contacts and I`ll see what I can find out for you.
Again sorry for your disappointment, but hopefully the issue can be resolved.
This page was generated in 0.514 seconds.
