162 Pages «<147148149150151>»
#2961 Posted : 25 November 2014 00:30:09
samson wrote:
Hi Alan
So finly Riggin BigGrin . looking amasing Cool .
Cheers
Jens
Hi Jens, thanks for looking in.... Rigging is getting close but still a lot to do to get the masts ready first, that's what I'm starting to work on now....Cool Cool ..Hopefully won't be too long before I post progress... Thanks again..
Ponty
#2962 Posted : 25 November 2014 04:23:58
Hi Alan, Your build looks just stunning!Drool
#2963 Posted : 25 November 2014 15:34:11
Thank you for your very kind comment Ponty, really appreciated....Cool Cool
#2964 Posted : 25 November 2014 18:27:36
Hi again Alan.
The turntables are very handy at times, the one I've got is plastic, 9" in diameter and about 3/4" high including the little rubber feet. It's actually a cake stand! One of the cheapest places to get one is from a cookery shop. I would imagine a 12" would be better for the SOTS size of model but they probably go up to 24" (Wedding cake size!) Despite being plastic they can take quite a weight (suppose they'd have to with a huge cake on them!)BigGrin
One good thing with them, if you do accidentally catch a protruding part of the model they tend to spin around reducing the chance of breaking something, but saying that, they're a right nuisance if you're trying to paint something and then it moves!!Blushing
der Gohfelder
#2965 Posted : 25 November 2014 21:39:07
Hi Alan!
Very nice work, I really like it! Rigging is coming soon, it will be a new challenge! BigGrin
Kind regards, Bernd
mark 2
#2966 Posted : 26 November 2014 07:29:15
Hi Alan BigGrin .
What a fantastic work of art you have done Love Drool .
Absolutly briliant.
Keep up the great work.
Best regards.
#2967 Posted : 26 November 2014 11:36:55
Excellent job there Alan, she is looking great. Well done
#2968 Posted : 26 November 2014 21:39:56
Top Job as always AlanCool
#2969 Posted : 26 November 2014 23:30:39
Plymouth57 wrote:
Hi again Alan.
Hi Robin, thanks for the info.... Now have a Monitor turntable on order so should arrive in the next couple of days.... Cool Cool .. Thanks again..
#2970 Posted : 26 November 2014 23:31:50
der Gohfelder wrote:
Hi Alan!
Kind regards, Bernd
Thanks Bernd, working on the masts at the moment so once they are complete then yes, the rigging will start.... Cool Cool .. Thanks again..
#2971 Posted : 26 November 2014 23:34:01
mark 2 wrote:
Hi Alan BigGrin .
Absolutly briliant.
Best regards.
Thank you Mark for the very kind comments... appreciated...Cool Cool
#2972 Posted : 26 November 2014 23:34:53
Thanks Hans, appreciate you looking and your kind comment...
#2973 Posted : 26 November 2014 23:35:33
Thanks Jase, appreciated...
#2974 Posted : 27 November 2014 00:25:51
Hi Alan,BigGrin
Must be getting seriously close to one heck of a load of rigging soon.
Blink Blink Blink Blink Blink
Work to date is a full on delight and can`t wait to see each instalment. Cool Cool Cool
Keep up the good work.
#2975 Posted : 27 November 2014 09:31:40
delboy271155 wrote:
Hi Alan,BigGrin
Thanks Derek, appreciate you looking in a commenting... Cool Cool .. Busy on the mast right now which is going to take a little while but once they are done then the rigging will start..... a new experience and hopefully a lot of fun too.....Huh Huh
#2976 Posted : 28 November 2014 22:52:03
Hi all, today I managed to finish the mainmast, a lot more work to this than originally thought...Blink Blink.. Deviated from the build instructions here by deciding to make up all the blocks and tie them to the eyebolts prior to fitting to the fighting tops... Cool [cool). They blocks supplied I thought looked to clean and new so gave them all a coat of light oak, think it looks better... Its important here to follow the plan very closely when it comes to fitting the blocks as it is very easy to place them in the wrong position....Cool Cool .. Mast assembly is straight forward but do ensure you place the coaming ring on the mast prior to applying the banding otherwise you may find the ring won't slide over the banding..Blink Blink .. Double check you have the fighting tops fitted with the correct orientation and ensure all fighting tops line up correctly.... Final task was to fit the eyebolts and blocks onto the mast caps.....Cool Cool .. It is also worth pointing out here, look closely at the lower mast cap for the main mast on the mast plan assembly and you should notice there are two small holes next to the hole for the second mast section. These holes must be drilled and I didn't see them mentioned in the assembly instructions. Drilling them before fitting is far easier than trying to drill them when the mast is in situ..... I used a 0.5mm drill bit and tested to ensure thread could pass through them easily. Cool Cool ... Mast is now sitting in place, has not been glued as yet....Cool Cool .. Hope to finish the mizzen mast over the weekend.... Happy building all..
#2977 Posted : 28 November 2014 23:07:30
For those that have not seen DeAg's xmas promotion yet then have a close look here...
http://www.model-space.c....utmcsr=model-space.com|utmccn=(referral)|utmcmd=referral|utmcct=/gb/&__utmv=-&__utmk=109118662
Great price reduction on lots of kits and great to see the SOTS is in there too.... If you are thinking of building this kit then take advantage of their offer....Cool Cool
#2978 Posted : 29 November 2014 16:15:13
Fantastic work Alan, well done Cool
#2979 Posted : 29 November 2014 18:02:59
Fantastic work Alan, she really is lookng quite stunning, you have done such and amazing job so far
#2980 Posted : 29 November 2014 22:48:26
Thanks Mr T, appreciate your comments as always... Cool
Guest (14)
This page was generated in 4.319 seconds.
