11 Pages «<45678>»
Stevie's Santisima Trinidad Build Options
samson
#101 Posted : 25 November 2014 00:13:43
Hi Stevie
Lovly ship you build . and very fin quality job you don on it BigGrin . looking forward to next opdate .Cool
cheers
Jens
Ponty
#102 Posted : 25 November 2014 02:32:37
Hi Steve, stunning work on this beauty"Cool Cool
#103 Posted : 29 November 2014 20:56:25
Thanks guys, Well I managed to get the painting done on one side today, some little touchups needed but there is also a 1mm white trim to go above each wale so not too concerned of any tiny leaks as they are hidden.
I painted the base red first then masked for the wales painting, I then re-painted the masking in red to seal any gaps and when dry painted the black.
The black paint is the admiralty dull black which I always find too shiny so will be giving it a once over with some humbrol matt cote later. I have painted down beyond the waterline, this will be marked off later ready for the coppering.
#104 Posted : 29 November 2014 21:50:43
Hi Steve, BigGrin BigGrin
Great stuff, Cool Cool Cool
Do agree that if that`s dull black, then it needs toning down without a doubt. (Very Shiny for Dull)
Still wonderful stuff.
#105 Posted : 29 November 2014 22:00:37
Thanks Del, Yeah- it's the same paint used on my Vic, very nice paint though but certainly not "dull" although it's not as shiny as appears in the pics, more of a satin id say. The humbrol matt cote cured the Vic paintwork perfectly so will be fine on this one tooBigGrin
Cheers
#106 Posted : 29 November 2014 22:42:47
Looking fab Stevie, the red and black are really striking and to be honest, I love it..... tone down the black is right and the whole hull will look superb when the tiling is done.... Drool Drool ... Very well done....Cool Cool
#107 Posted : 29 November 2014 22:58:28
Thanks Alan, it's certainly been a nice change to paint a bit of red on a ship buildBigGrin Even my wife likes itLaugh
Will post again when the matt cote is on but I know it will be fine.
#108 Posted : 29 November 2014 23:50:41
Excellent work Steve, really liking how the colours of turned out.
What brand of paint is the admiralty paint, is this all hand painted or do you airbrush?
#109 Posted : 30 November 2014 09:28:11
Hi Steve,
Great build again looking forward to more pictures, thank you for posting.
Trev.
jack.aubrey
#110 Posted : 30 November 2014 15:41:58
stevie_o wrote:
. . I painted the base red first then masked for the wales painting, I then re-painted the masking in red to seal any gaps and when dry painted the black . .
Very nice colouring, Steve . . Good job !!
I've read you have used the trick of colouring the masking tape to seal the gaps before painting black. I was told time ago about this simple trick but I never had the possibility to use it. It seems really to properly run, isn'it right ?
Regards, Jack.
#111 Posted : 30 November 2014 20:25:30
BigGrin She looks very striking in those colours and even better than the pics. Nicely done.Cool
#112 Posted : 30 November 2014 21:37:18
Hi Steve, BigGrin
Just a quick bit about masking tape.
When masking up my SotS build I used "Frog Tape", the low tack variety.
Looks like you may be using the same brand looking at the colour of it!!
One thing they say in their ads, is that you can "run a water, wet /damp brush along the edge of the tape once applied" and this makes a better edge seal prior to painting.
Done this with my SotS and it worked a treat, no leakage.
#113 Posted : 30 November 2014 23:38:39
Thanks for the comments Trev and Andy, really appreciate you followingBigGrin
@Dave, the paint is Admiralty by Caldercraft - http://www.cornwallmodel...ralty_paints_water.html
it is specially developed for 17th, 18th and 19th century ships. The paint is available in sets for many ships or also individually.
@Jack, the painting over the masking tape with the same colour first seems to work very well for me, you can also use a clear varnish to paint over first instead.
@Del, the masking tape I use is called Stuk Proffesional from CMB, it seals well and is fairly lo-tack too. I think once you find one that you like you tend to stick with itLaugh
Anyway, just a pic to show the matt cote worked very well and has taken all the shine out of the black apart from a very slight satin finish which I quite like. The red looks a bit orange in the pic but this was just the lightBigGrin It's really very bright red!
#114 Posted : 01 December 2014 16:53:53
Hi Steve.
Looking fantastic. realy nice coulour scheme.
Look foeward to seeing more of your build IanCool Cool BigGrin
#115 Posted : 03 December 2014 12:58:07
Thanks Ian,
Finished adding the white 1mm trim strips, these were obviously painted before fitting to avoid having to mask them off. The blue colour is also going to be used on the gallery, it looks very red at the mo but there is no more red to add on the entire build so it should look better as more is added.
Cant wait to get the gunport frames in now so may jump ahead and start this next to cover up the raggedy port cutoutsBigGrin
#116 Posted : 03 December 2014 18:50:41
I really like how the white has come out, it really breaks up all that red nicely. Great work
#117 Posted : 04 December 2014 12:29:32
nice paint job there steve,looks the bizCool
#118 Posted : 04 December 2014 23:13:17
#119 Posted : 04 December 2014 23:19:57
Now that I love, the white strips truly make those colours stand out.... excellent work Steve....Love Love Love
Ponty
#120 Posted : 04 December 2014 23:24:38
Hi Steve,
I love the contrast between the colors. Looks outstanding Cool
Can't wait to see her when you copper tile her!
Guest (19)
11 Pages «<45678>»
This page was generated in 0.331 seconds.
