Left intercooler bottom is not flat Options
Uncle Al
#1 Posted : 11 December 2014 00:51:03
Rank: Beginner Level 1
I just got pack 5. The Left intercooler bottom is not flat where it attaches to the intercooler has anybody tried to straighten it?
I don't want to damage the finish.Confused
Warthog
#2 Posted : 11 December 2014 08:26:10
Hi Al
Can you provide us with a picture so that we can see what you mean.
Spencer
Uncle Al
#3 Posted : 11 December 2014 17:16:32
The gap is at the forward bottom end.
I have pictures but don't know how to attach them
gaps 003.JPG (1,937kb) downloaded 118 time(s).
gaps 001.JPG (2,069kb) downloaded 111 time(s).
Warthog
#4 Posted : 11 December 2014 19:07:39
Hi Al
Thank you for providing the pictures and at close inspection it does look very much like you do have a faulty part as the left inter cooler buttom should be straight. You can check this by putting a straight edge along the top surface edge.
You will need to contact Customer services for a replacement... Details below
Email: customerservice@deagostiniusa.com
Or call: 1-877-544-6779
Spencer
DaDokta
#5 Posted : 11 December 2014 19:15:03
As far as i understand it, you first pressed the two intercooler sideparts towards the "round tube" thing behind the intercooler, which caused the sideparts to deviate - hence the gap at the front.
You should go the other way and first press the sideparts towards the intercooler over the whole lenght. The "tube", which is a little bit too short, is allowed to have some space towards both sideparts as long as it reaches both sides and can be glued.
I hope my english was understandable,
DaDokta
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
DaDokta
#6 Posted : 11 December 2014 19:18:10
But of course, if the sidepart is not straight - you can`t do anything but call for replacement.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
This page was generated in 0.121 seconds.
