5 Pages <1234>»
Dokta´s McLaren MP4/4 Options
Steve279021
#21 Posted : 11 December 2014 09:13:10
coming along nicely. Some good pics you got thereBigGrin
Dodge charger build complete
Senna lotus 97t complete
#22 Posted : 19 January 2015 10:25:17
Making great progress DaDokta, she looks great and your work looks very neat and tidy - well done. Cool ThumpUp
Steve279021
#23 Posted : 22 January 2015 11:46:32
looking good dadokta. did you have any issues gluing the cockpit in. mine seems to have stuck now but didn't first time and when it came off first time it looked as though the glue hadn't even made contact where the back of the cockpit meets the back of the headplate?
DaDokta
#24 Posted : 24 January 2015 15:41:09
Hi Steve,
yes i actually had problems glueing the cockpit as well.
Had to try it twice.
Even after the second time the cockpit sat about 0,2mm too far to the rear - which at first i thought wouldn`t be an issue.
But it was an issue when adding the ground plate, which - as it is screwed onto the cockpit - also sat 0,2mm too far to the rear.
With the cockpit already fixed i had to take away those 0,2mm at the end of the ground plate, to make it fit.
Without knowing it, one can`t see any difference - so i`m content with the result of the little surgery.
Greetings,
DaDokta
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Steve279021
#25 Posted : 17 February 2015 12:55:26
Well done. Them hoses look like they've come out quite good.
DaDokta
#26 Posted : 18 March 2015 22:05:29
Hi guys,
i tried to enhance some parts of my build a little bit:
First i tried to add some depth to the gearbox, using the dry-brush-technique for the first time in my life. Also painted some of the bolts:
Then i added the sponsor decals to the monocoque and painted the bolts
[size=8]Also some touches to the side boxes:
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Phil
#27 Posted : 18 March 2015 23:23:19
Looks great mate, the bolts really set it off!
Building the MP4/4!
mark8454
#28 Posted : 19 March 2015 07:16:17
Fantastic! Love the heat staining!! I will be keeping an eye on this build for sure!!
ian2014
#29 Posted : 16 April 2015 13:19:43
Very nice Walter. Ian
Facebook-model maker
DaDokta
#30 Posted : 16 April 2015 15:20:09
Thanks guys!
Looking Forward to the next shipment.
Walter
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#31 Posted : 16 April 2015 22:05:53
Hi Walter,
Great job with this build and great to follow.
Trev.
#32 Posted : 16 April 2015 23:21:14
BigGrin Very nice work thereCool
#33 Posted : 17 April 2015 11:03:13
Fabulous work DD and one of the better MP4/4 builds on here inmho, I love the heat-stained radiator tops!! Drool
Love all the little extras you are adding and the detail painting is great. If I may suggest though - don't overdo the wear and tear and weathering on your model as these cars were nearly always kept in tip-top condition and cleanliness was usually the name of the game? I think subtle weathering is all it needs, anything more would just look wrong?
Great work nonetheless DD and well done, I'm looking forward to seeing more from you!! Cool ThumpUp
Steve279021
#34 Posted : 29 April 2015 10:02:25
Coming along nicely. That's the stage I'm at too.
#35 Posted : 29 April 2015 15:33:43
Very nice work, I really like the look of those braided hoses Cool
RM1
#36 Posted : 29 April 2015 17:08:25
Very nice, those little extras make a big difference.
I can't wait to get stuck into my build.
Malc.
#37 Posted : 29 April 2015 20:41:48
BigGrin Great work Walter, looks the bizzCool
DaDokta
#38 Posted : 30 April 2015 08:32:53
Thanks guys for your nice comments!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#39 Posted : 29 May 2015 09:28:35
Good morning,
here are some pics of this months shipment.
Again i did a little touch-up with Aluminium paint and a some dry-brushing:
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Steve279021
#40 Posted : 29 May 2015 09:34:46
Looking good Walter. I'm on this pack at the moment but struggling to find time to finish it.
5 Pages <1234>»
This page was generated in 0.120 seconds.
