Tight piston Options
Ted the bullet
#1 Posted : 14 December 2014 21:12:09
Rank: Beginner Level 1
I have big problem!! my piston will not go to top of cylinder; it seizes about 3.5mm from the top.Huh So' I suppose I've got to make a small hone put in my small drill. has anyone else had this problem? I thought I was getting on to well: for I don't suppose I can get a replacement.Glare [img]
#2 Posted : 14 December 2014 21:20:48
BigGrin Hi Ted
The motor provided is what is known as an abc engine and has a tapered cylinder liner thus the piston will stick at the top but when its run in its fine, please see the link below to help you answer your question.
http://forum.model-space...spx?g=posts&t=12278
http://www.mecoa.com/faq/abc/abc.htm
Hope this helps.
This page was generated in 0.153 seconds.
