16 Pages «<1213141516>
ARPurchase's build of the D51 Options
#261 Posted : 14 December 2014 22:52:05
This looks great Andy, yet more fanatastic work,
#262 Posted : 14 December 2014 23:27:18
BigGrin Thanks for looking in everyone and your comments . She certainly is starting to gain weight now but at least the base should take it.Cool
#263 Posted : 17 January 2015 19:41:34
This months parts are here including the two base ends but Il assemble these with the centre section when I get it. The rest of this months parts are I think the last for the Tender which have been added and painted.
I had decided at the build outset to replace what looked to me to be the plastic moulded coal with some coal from a railway diorama specialist of which I bought 2 packs of the O + Gauge 1 size which is the closest I could find to our 1/24 model and looks about right in size to me.
This is how I placed the coal in the tender, firstly cut a base plate that fits inside the tender from the parts backing card and glue in place. Then dilute some PVA glue with water add the coal and mix together so all the coal has a coating of the PVA mixture. Carefully add this mix to the tender and spread it out until your happy with its look and then leave to dry overnight.
I may add another bag to give it a more piled up look but I might not, If anyone is interested in doing the same with there tenders I will add the link below 2 bags will give the look i have on the tender right now if you want it higher then 3 bags should do it.
http://www.ebay.co.uk/it...amp;hash=item23475df58c
#264 Posted : 17 January 2015 20:44:34
#265 Posted : 17 January 2015 20:45:56
The coal is spot on, it looks real and the paint on the tender is as life like as you could want. Excellent build.Love Drool BigGrin
#266 Posted : 18 January 2015 00:03:48
Looking superb Andy and great idea with the coal, looks so much better than moulded plastic.....Drool Drool ..
#267 Posted : 18 January 2015 00:33:46
BigGrin Thanks every one for looking in and your comments, the coal is not real coal but a mineral that looks and weigh's the same without the dust and the other reason for using PVA as a fixative is that when dry it gives that shiny/oily look that real coal has when the light catches itCool
#268 Posted : 18 January 2015 01:41:32
The coal really does look real
Awesome job
mark 2
#269 Posted : 18 January 2015 08:53:28
Hi Andy BigGrin .
I Love the coal Also it looks fantastic Cool .
I hope you don't mind me saying that another way of doing the coal in the tender is to use polystyrene as a base plate as you could have it thicker and then do your method on top. That way You might only use 1 bag of coal.
Great idea with the coal.
I look forward to seeing more.
Best regards.
#270 Posted : 18 January 2015 09:39:15
BigGrin Hi Dave and Mark
Thanks both for looking in and your comments, the polystyrene is a good idea but after the inner base plate is fitted the gap is around 2/3 cm from the base to the top side edges and a cut out at the front will be needed so the coal can be seen at the top of the stokers hole.
#271 Posted : 18 January 2015 12:22:36
That looks brilliant and the change from the moulded coal insert to scale coal makes all the difference.
Have you decided how you are going to finish your base? From the builds I have seen those plastic ballast inserts do not appear to fit together very well (appear to have gaps between) so would be really interested to see if it's possible to produce something similar using real ballast. Guess the issue will be ensuring the rolling road is not fouled and again (still months away from that stage) if you need access to the innards of the base for battery changes etc.
Excellant update as always
#272 Posted : 18 January 2015 12:48:29
BigGrin Hi Tony
Thanks for looking in and your comments, looking at the base with the plastic track ballast I think it would be possible to replace it with a scale type ballast like the coal in the Tender.
The best way to do this would be to use the plastic ballast as a template to fix the sleepers in place. Then where there are the larger square holes around the sound box and main wheels use a clear plastic strip or some wood strip to form boxes once all that is in position remove all the plastic ballast and refill with the replacement ballast.
#273 Posted : 18 January 2015 16:38:47
Thanks for your comments. Still a way off from that stage but will bookmark this for future reference.
Kind regards
Tony
DaDokta
#274 Posted : 19 January 2015 08:25:16
The "coal" looks fantastic! I will remember this, when i get to that stage.
Greetings
DaDokta
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#275 Posted : 19 January 2015 18:14:23
BigGrin Hi DaDokta
Thanks for looking in and your comments, Glad you like the coal idea
#276 Posted : 14 February 2015 19:23:04
Stage 22 arrived so the base plate has now been made up and the electrics added, just a couple of pics as others have already posted more detailed ones.
#277 Posted : 14 March 2015 22:47:57
Pack 23 arrived, added the effects generator and connected all the wiring plugs including the motor and lighting looms. Next job was to add the ballast parts,sleepers ball race brackets and rails. Finally add some battery's to test out the sounds from the generator. More soon.
#278 Posted : 14 March 2015 23:25:42
Looking good Andy, certainly looks like a stunning base for the finished article to be displayed on.... Cool Cool .. Look forward to your next update...
#279 Posted : 15 March 2015 10:32:30
BigGrin Hi Alan thanks for looking in and your comments just 2 issues left nowCool
#280 Posted : 15 March 2015 16:48:46
Lucky you - just 2 more to go and you will have all those great sound and lighting effects to "play with".
I have just had my pack 10 set through and have the sand pipes to finish this despatch.
You have made a lovely job of your build and hope you have enjoyed the build as much as I am.
This page was generated in 0.243 seconds.
