17 Pages 123>»
benny's build Options
benny
#1 Posted : 25 August 2010 18:26:49
well here goes..i thought i would start off with a few pics of the finished pieces we first received, a few stages are missing but thats down to my nikon coolpix, seems to struggle with close up shots as you will see with a few pictures i will put on here.. (any advice is welcome but i think its the camera) so first is the anchor i thought i would wear out the edges a bit to give it a worn look,
cheers benny
benny
#2 Posted : 25 August 2010 18:29:32
the cannons..3 times i built these to get a standard i thought was acceptable..the ends are red ochra and 2 coats of satin clear
cheers benny
benny
#3 Posted : 25 August 2010 18:30:50
cheers benny
benny
#4 Posted : 25 August 2010 18:32:05
the launch..what a pain in the arse..i stripped it down 4 times..now i have something which is the level of my capabilities
cheers benny
piot007
#5 Posted : 25 August 2010 18:44:34
see if your camera has a 'macro' setting. (zoom is disabled) well it is on my camera. Also plenty of light, natural light is prefered failing that artificial will do.
your build is coming on nicely. Im not brave enough to carry on lol. I need some rum to continue, maybe somebody could spare some of that smuggled brandy! BigGrin BigGrin
Son of Bulwark
#6 Posted : 25 August 2010 18:45:39
Hi benny! BigGrin
I see you've start your diary good for you!, the worn look of your anchor makes it look like it been used alot. Laugh
The sea bed isn't just sand looks like the stock hit a number of rocks, spot on! Cool
As for your problem with focusing on a close up shot use a small tripod and use the timer function, this will reduce any shaking also use the zoom to max and move a little further back. It's what I have to do as my camera is worse than yours. Crying
Keep up the good work.
ThumpUp Darron
benny
#7 Posted : 25 August 2010 18:48:22
3 coats of satin varnish
cheers benny
benny
#8 Posted : 25 August 2010 18:50:30
the launch before i cleaned it up.. controlling the glue must come with practice
cheers benny
benny
#9 Posted : 25 August 2010 18:54:23
the sail i painted with a mixture of walnut stain and wood glue to give a worn/aged affect
cheers benny
benny
#10 Posted : 25 August 2010 18:58:29
cheers benny
benny
#11 Posted : 25 August 2010 19:03:00
son of bulwark and piot thanks for your tips will try them out and thanks for your comments
cheers benny
benny
#12 Posted : 25 August 2010 19:12:05
if we ever have a forum/build meet up i will buy you a large one
cheers benny
benny
#13 Posted : 25 August 2010 19:15:27
cheers benny
benny
#14 Posted : 25 August 2010 20:05:14
now start of the jig and the initial build not in the class of bulwarks jig and i must say that was impressive but the simple oak shelf and metal right angle worked for me
cheers benny
benny
#15 Posted : 25 August 2010 20:07:03
cheers benny
benny
#16 Posted : 25 August 2010 20:18:11
now we have the decks its time to install the ribs..which have been on press, well, it seems for months..
cheers benny
benny
#17 Posted : 26 August 2010 16:59:19
cheers benny
benny
#18 Posted : 26 August 2010 17:02:57
time to get the decks in..the pin pusher from deag caused no problems at all
cheers benny
benny
#19 Posted : 26 August 2010 17:04:40
cheers benny
benny
#20 Posted : 26 August 2010 17:06:09
now the bow formers
cheers benny
Guest (14)
17 Pages 123>»
This page was generated in 0.146 seconds.
