Tight cylinder Options
russell2
#1 Posted : 16 December 2014 14:50:24
Rank: Newbie
Hi ,
I have just received pack 15, parts 57- 60, and attempted to assemble parts 57, and 58.
The piston will only move up the cylinder until it is about 7mm from the top.
Because of this the crankshaft will not rotate fully as the piston does not reach TDC.I have tried a tiny amount of lubricant in the cylinder with no success.
Does anyone have a solution apart from a replacement pack 15.
#2 Posted : 16 December 2014 14:56:57
See this topic and the two links within..
http://forum.model-space...=135116&#post135116
This page was generated in 0.265 seconds.
