5 Pages <12345>
DaDokta´s D-51 build Options
DaDokta
#41 Posted : 29 December 2014 09:07:14
Hi guys,
i finally found some time to finish the next shipment.
Fitting the two cables into the connector was quite challenging!!
The opening-mechanism for the smoke-box-door sits very loose - but i guess, there`s nothing i can do about that?
Thanks for looking in!
DaDokta
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#42 Posted : 29 December 2014 09:21:42
BigGrin Nicely done ,as for the smoke box handle mine is the same bit its fine when tightened up with the rear plateCool
#43 Posted : 29 December 2014 10:39:33
Lovely work, a pleasure to follow your progress.....Cool Cool
#44 Posted : 29 December 2014 10:58:35
So pleased to see you enjoying this build as much as I am. It really is a great model.
Looking at your pictures you are one pack ahead of me so I have the main boiler parts to look forward too next month Love
Hope the rest of your build goes well.
#45 Posted : 29 December 2014 11:34:47
This is really starting to look fantastic, you are doing a lovely job. Look forward to seeing more
DaDokta
#46 Posted : 30 December 2014 09:32:40
Thanks for your nice comments, guys!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#47 Posted : 25 January 2015 23:31:46
Definitely starting to look like a showpiece, very well done....Cool Cool
#48 Posted : 26 January 2015 22:19:07
BigGrin Looking greatCool
DaDokta
#49 Posted : 27 January 2015 07:56:11
Thanks guys!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#50 Posted : 25 February 2015 08:45:12
Well guys - i´m afraid i had not my best day of model-building yesterday.
All went well at first when fitting the sand pipes and the little brackets.
But as i worked on the opposite side, the brackets came loose again and then i spilled super glue all over the boiler.
Well the damage is done - maybe i will have to paint now.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#51 Posted : 25 February 2015 09:18:00
Hi DaDokta
Sorry to hear about your mishap, its a little late now but you could have tried using Locktite's super glue remover gel to remove the offending excess glue,
http://www.ebay.co.uk/sc...emover+gel&_sacat=0
I have used it a few times now but mostly on etch parts and it works if left over night. One other thing to watch is that the sand pipes may need a little adjustment to fit into the channels in the side walkways when they are fitted. keep up the good work
DaDokta
#52 Posted : 21 March 2015 19:50:33
Hi guys,
some progress on my D-51!
I applied Roys Gauge-Decals and covered them with Crystal Clear.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#53 Posted : 21 March 2015 21:52:50
BigGrin Starting to come together now Walter, top workCool
#54 Posted : 21 March 2015 22:39:49
looks fantastic and i bet it is starting to get heavy now
#55 Posted : 29 April 2015 15:21:16
Wow that is a really clean build.You must have handled the brass parts really carefully for them to stay so shiny.It is good to see it next to some other kits so you can see how big it is.
#56 Posted : 29 April 2015 20:30:07
BigGrin She looks great Walter, great stuff Cool
#57 Posted : 29 April 2015 22:06:42
Walter
A sheer inspiration.
I can see you are getting some great fun from your building.
I am into the D 51 and have followed the instructions on the basis near the end they tell you how to take it apart to paint.
Most of the builders have already started to paint the wheels etc so not sure if I have gone a bit to far as I do want to paint me.
Hope the rest of your builds go well.
#58 Posted : 29 April 2015 22:45:41
Fantastic work, so clean and neat and some other great models on the go too Cool
DaDokta
#59 Posted : 30 April 2015 08:37:41
@Tony
I will leave mine in brass - as i`m afraid my painting skills would ruin more than make it look better.
Actually i don`t own an airbrush at the moment - it`s one of my Projects for this year to buy one and learn how to work with it.
Greetings,
Walter
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#60 Posted : 30 April 2015 10:24:20
Looks great Walter, very well done indeed.....Cool Cool
5 Pages <12345>
This page was generated in 0.238 seconds.
