 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,496 Points: 4,400 Location: Essex
anyone else have a problem gluing the steering slider gear to the steering slider? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
Hi Steve In what way do you mean a "problem"? Regards Spencer
it seemed quite a loose fit and trying to get it to sit right whilst holding it in position waiting for the glue to dry was a bit tricky and it was a bit loose. I seemed to have sorted it now by throwing some more glue on it when it dried. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Cool  . It is fidly due to the size but once the glue takes hold and sets completely then you should be ok. Spence
 Rank: Semi-Pro Level 2    Groups: Registered
Joined: 14/03/2013 Posts: 96 Points: 287 Location: England
Steve279021 wrote:anyone else have a problem gluing the steering slider gear to the steering slider? I had the same problem. Had to use a small amount of super glue in the end. Building: RB7 Nitro / Senna MP4/4 Finished: McLaren MP4/23 Brad.
