Question Options
#1 Posted : 04 January 2015 08:37:42
BigGrin Nice work AlCool
Brewis
#2 Posted : 22 July 2015 10:54:10
Rank: Newbie
Have you (or anyone else) found a couple of possible problems with the rear wheel?
The notch in the inside of the sprocket is distinctly wider than the tab on the hub which fits into it on mine. This means that after assembly the sprocket can be rotated by a few degrees in either direction relative to the wheel. Obviously on a real bike it would be tightly locked to the wheel so that they can only rotate together. Not sure if this is going to cause problems - I suspect it will, and am considering gluing them together. Any thoughts?
I've also found that when I tighten up the nut on the rear axle, I have one of two problems. If I do it gorilla-tight, the wheel doesn't rotate very freely at all. If I don't do it quite so tight then the axle and nut are able to rotate themselves - again, presumably the axle and nut oughtn't to rotate; they should be fixed, and only the wheel rotates about them.
#3 Posted : 22 July 2015 18:24:24
Hi brewis my bike does the same.but can't see it causing problem in the future.but if you do wish to glue, I'd not do it now as these models tend to require disassembly at times.I don't know if rear wheel will need taking out again.but gluing now would make this impossible.and would be easy enough to do at end of build if your not happy with these parts being loose.cheers mick BigGrin BigGrin
#4 Posted : 22 July 2015 20:22:21
Hi David
The wheel and sprocket on my build was exactly the same as yours and it has no effect on the build at all when finished, the only reason I think it is like that is so when the model is moved there is some give between the wheel and sprocket so as not to put excess strain on the plastic cog holding the chain at the gearbox end. Personally I would not glue the parts together for this reason.
Again my bolt and nut was fine but you could use a spot of thread lock to cure this. Hope this helps.
This page was generated in 0.095 seconds.
