Hi Derek  . I look forward to your build diary of the Lancaster  . Best regards to yourself and family for 2015. Mark
Hi, Jase, Alan and Mark. Thanks for looking in,  and issue 1 of 125 should be posted tomorrow with any luck. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Well here we go. Will post this build as a weekly issue set up. May be able to get more/or less in a week depending on how much work there is to be done and other commitments. So here we go with issue number one: THE PARTS. Pic 1 The propeller and the two bombs are not used at this point, (to be shown later). The wooden fret and the plastic stringers are all used to construct the nose cone of this Lancaster. All parts removed from the wooden frets will need sanding smooth at the points where a piece is cut from the fret. First job was to number the parts before removal from the fret, then glue the two web braces to the rear former of the nose section.Pic 2 Next attached the front turret base former.Pic 3 A small vertical former was then fitted to the back plate.Pic 4 The next former to be fitted needed some careful positioning as it had to be rotated into it`s final position.Pic 5-6 Another vertical former was then added to the top of the nose construction.Pic 7 The next former was open ended and had to be carefully positioned so as not to snap it.Pic 8 At the open end of the last former, two more vertical formers are now added for support.Pic 9 Another open ended former added.Pic 10 A small vertical former plus last open ended former are now added.Pic 11 Two vertical side braces are now fitted, followed by a very small vertical former and the final nose cone ring.Pic 12 That`s the plywood construction of the nose cone done for now. Starting from the top of the nose section, the plastic stringers are added.Pic 13 Top section of stringers completed.Pic 14 Three stringers added to each side and the lower section stringers fitted and the nose cone is finished for this issue.Pic 15 So that`s the end of issue one and this is where I`m at.Pic 16 So, issue one complete. "ISSUE 2 COMING SOON" Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
A lovely start Del! I really enjoy watching this type of construction take shape, the way complex curves are formed from essentially flat bits and bobs still seems like magic, even now! Watching with great interest! Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
 Nice start del Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Del Nice start on a mammoth project. Is this a complete set you picked up or did you collect it from when it was issued? Looks like you have the knack of working with those plastic ribs which I know did cause some problems for some builders. Hope the rest of your build goes well. Happy Modelling
Hi Nem, I`m into the build of the Deag spitfire, Wifey bought me an "Airfix" 1:24 Hurricane for part of my Chrissy present and I have this Lancaster build. Three out of your favourite four can`t be bad. As for this build, I`m finding it very enjoyable at the moment, but only time will tell. I won`t be put off the build but you never know what may crop up in a build that may need sorting and can put a halt to proceedings. Thanks for looking in. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Plymouth57 wrote:A lovely start Del! I really enjoy watching this type of construction take shape, the way complex curves are formed from essentially flat bits and bobs still seems like magic, even now! Watching with great interest! Robin Hi Robin, The way these kits are designed still baffles me a bit, but if it all comes together as well as issue one, I`ll be a very happy bunny. Thanks for taking time to look in. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
arpurchase wrote: Nice start del Hi AR, Thanks for looking in, the start has been a pleasure to build. Hope the rest is the same. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
birdaj2 wrote:Del
Hope the rest of your build goes well. Hi Tony, Yep a mammoth project in deed and I picked it up as a complete kit. As for the plastic ribs, the copious amounts of super glue (Gel)and cocktail sticks seems to work for me. Just as well, as there are shed loads more to come. Thanks for looking in and the comments. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Del, Great start to your build,very clean work looking forward to more posts. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Lovely start Del, really looking forward to more of this one Steve
tf64 wrote:Hi Del, Great start to your build,very clean work looking forward to more posts.
Regards Trev Hi Trev, Thanks for looking in. More work already underway. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
stevie_o wrote:Lovely start Del, really looking forward to more of this one Steve Hi Steve, Issue 2 very nearly ready for posting, (hope tomorrow)and work on issue 3 started, but a shed load to go before posting that one. Thanks for taking the time to look in. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Looks like you're off to a great start Derek... As with all of your builds I will be following this one with lots of interest..... Good luck with it..... Regards Alan
Hi All, Firstly thanks to Alan for looking in  and now here comes issue two. There`s not a large amount of work to do in this issue (constructing the left wing outer section), but, it does include the painting of one propeller and spinner that I will leave until another day. Reason being it`s not worth setting the airbrush up for such a small amount of painting. So here`s the rest of issue two. The parts: One plywood fret and a metal spinner.Pic 1 The important part of this construction is making sure the spar and wing ribs are set at the correct angle, bring in the miniature engineers squares.Pic 2 The rest of this part involves the addition of a further five ribs and the forward spar.Pic 3 When the next five ribs have been set at the correct angle to the rear spar and allowed to fully set, the front spar is added. While this was allowed to fully set I gave the first prop and spinner a basic clean up. This is the state of play at the end of issue two.Pic 4 So, what`s next in issue three? Fit the rest of the ribs in this wing section. Fit the aileron spar. Fit the left wing outboard engine mount. Fit plastic stringers to the main (upper) section of the wing. A busy section of the build. Happy Building Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
This is looking like great fun. could I trouble you for a penny shot give us some idea of size will follow with keen interest jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Del, Thanks for posting issue 2 it's very similar to the way we are building the spitfire,how are the wing covered on this model I would be very interested to know. All the best Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
