Build of the year 2015 entryHave settled on this as my entry, Update to this post to follow later this evening with more information and some pictures Many of you will know after following my Yamato that I am not a fast builder but will hopefully plod along at a steady rate PLEASE NOTE: This will be a separate build to my DeAgostini Millennium Falcon. I do not want my thread to be used as a spot the difference or comparison between the two. Please respect my thread and do not ask me to make comparisons. Thank you for your understanding
Dave Great choice of kit. Wish you very well with your new build. I built ( in my opinion) a really great generic lighting kit for a Star Trek enterprise a few years ago just wish I could try and post it as a video as I am sure there would be some interest. Look forward to your updates on the falcon as you have yourself a stunning kit to work with. Happy Modelling
 Nice kit il be looking forward to your build Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looks a good one Dave and good luck in the comp  I'll be watching! Steve
This is going to be amazing
Going to be a stunning build Dave and very much looking forward to your progress mate  Good luck with your entry Spencer
The build has begun Decided I will start off this build with the slow tedious job of filing and cutting out all the armour plate notches I havent decided if I am going to attempt the over hang of the armour plate over the mandibles yet, mainly as I really am not too sure how I could go about it or even if I would be capable. For those that arent sure what I am talking about, where I have cut notches on the 4th photo, where the vertical and horizontal meet there shouuld be an overhang rather than a straight wall. One idea I had was to put down some masking tape as a barrier to protect the plastic I dont want touched and then use a small sanding or cutting wheel on the Dremel to gently touch into the plastic  Hope that makes sense.
Top choice Dave and looking forward to this one. Spencer
Now this is going to be something special!  Looking forward to watching this build!!
Nice to see your competition build has kicked off Dave, look forward to more of this Steve
Nice to see you started Dave, going to be enjoying this one..... Regards Alan
Thanks for the comments Spencer, Darran and Steve I am thinking of really pushing myself with this, been thinking more about the over hand I think that I can do it with the dremelsanding disk. I have an idea of removing part of the pipe work in picture 4 for access then replacing it with a bit of styrene rod
I got a bit carried away on eBay, I actually went on to get hold of a switch and a 9v battery connector but ended up with this lot, wires, LEDs, Fibre optics, resisters and generic on/off PCB The right half is the lighting kit I already had and the left half is my eBay haul Think I have got every possibilty covered now
Still not a great deal happening with this yet due to Yamato getting in the way, I have all year though and this will become my main build once Yamato has been put to bed Just a small update, I have been searching for quite some time for the clear resin engine nosels to go with the lghting and have not had much success. After recently losing out to a set on ebay I decided to just spend the extra money and order some 3D printed ones from shapeways. They look pretty cool, will be dusted with a layer of Tamiya smoke
Dave starship modeler has some replacement clear resin engine grilles too http://starshipmodeler.b...-replacement-parts.html
Thanks, Everytime I checked them they were out of stock so gave up. All good now, think I have everything, maybe another switch and battery connector
Guest (16)
