Foremast and Bowsprit Options
#1 Posted : 12 January 2015 10:22:14
Confused Just a question when fitting the 2 masts dose the Foremast sit on top of the bowsprit or dose the bowsprit butt up to the foremast BigGrin Thanks for the help rgd Martyn
#2 Posted : 12 January 2015 19:32:33
Hi Martyn, good question as the instructions aren't really clear about this but the clue really comes in looking at the position of the rigging blocks fitted to the lower part of the bowspit, the rigging blocks sit either side of the first bowspit gammoning (the one nearest the steps)...Cool Cool, Mr T's Official Build issue 122 shows the positioning of these blocks very well in relation to the bow. In addition, the instructions do say to fit and glue the foremast in position as the first mast to be fitted so that tells you the bowspit butts up against the foremast and not underneath it.....Cool Cool . If you also notice from my build, the bowspit has not yet been glued into position, it is only sitting there when not working on the ship. Having to turn the ship around frequently to fit all the shrouds had me believing the bowspit was likely to be damaged in the process. I will be fitting the bowspit fully when it comes to rigging it in place.....Cool Cool .. Hope this helps and hope to see some of your lovely work real soon.....Cool Cool.... Should you need any further clarification then please let me know, here to help..
#3 Posted : 13 January 2015 17:29:55
BigGrin Thanks for the info Alan ThumpUp Hope to put some more pics up today BigGrin Rgd Martyn
This page was generated in 0.651 seconds.
