Looking very nice Trev, the wing skin looks fab Steve
Very nice work Trev, the end result is going to be something special.
Hi Trev, Loving this as always. You need to patent the rivet jig, that looks like an awesome idea. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
See Trev, I was so very confident you would come up with a solutionin designing a jig you could rely on.... excellent work on the jig with fabulous results..... Very well done.... Look forward to seeing the next lot of panels go on so keep up the great work.....  Regards Alan
Hi Trev  . I hope you are well. I think you have done a fantastic job with the jig for the panels. Its a bit more work making the jig but I must say that it is well worth the effort  . Fantastic job and please keep pics coming. Best regards. Mark
Great idea with the jig! I will copy that for my build, once i get to that stage.
How did you achieve that dull look of the plates? That looks great!
Greetings, DaDoktaGreetings, Walter
Hi Andy, Thank you for looking. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Kev, Thanks for your comments much appreciated. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hello Steve, Well Steve this is the first time I have skinned in metal, I have skinned with tissue and with Ply so this is a challenge to me which makes you think a bit, I still say you can't dry fit enough! Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Nem, Thanks for taking time to look at my build, I am keeping my fingers cross that it will all go ok, metal skinning is certainly different? Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Derek, Thanks for looking, well the jig seemed to working ok, working on another at the moment this will be to take on the larger panels with adjustment for size more to follow. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Alan, Thank you for your valued comments regarding the jig, I look forward to showing you the larger version which is underway at the moment. Regards Trev ps: Great work on the Sovereign have you seen the little figurine with issue 125 that will take some painting. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Mark, Thanks for looking, and your comments always valued, I must say that what is looking great is your D-51 build the time and effort you are putting in is clearly seen by your pictures well done. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi DaDokta, Thanks for the comments about the jig, the reason I dulled the plates down was because the wing was a bit to shinny for the camera, just think how bright it will be when completed. I will be spraying when finished. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE:SPITFIRE 100215. Stage 64/65 Stage 64 First job was to identify wing plate 12 then lay it on the template and mark the rivet lines, having done that the next job was to sand the side to be stuck to the wing. Once the plate has dried pierce a hole in each corner with the awl supplied.  This is the picture with number 12 plate in position.  Stage 65. The next part was to assemble the Landing Gear Housing I found for this you will need, Sandpaper,Hobby knife,File, Glue, and a small hand Saw. First thing remove all parts from the fret Housing received in pack 64 and smooth of all edges.  Position the base of the Landing Housing on a flat surface, then test fit the two sides into the notches on the base,glue the first side in place.  Then the second making sure that they are at 90'  Next locate the two ribs in the wing then cut away the bottom of the two ribs(Remember the wing is upside down) next file and smooth the rib edges.  You can see where I have filed and smooth in this picture.  With the Landing Gear Housing make sure you test fit before you glue because it has to be below the Spar otherwise you will have trouble fitting the metal plates.  This picture shows the wing with number 12 plate in position plus Landing Gear Housing fitted. Thank you for taking the time to look at my build more soon. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Very nice work indeed!!! The skin is looking spot on!!
Fab Trev, a very well executed build session and well described.... Wing looks bril... Regards Alan
Your build is looking brilliant! Cheers, DaDokta Greetings, Walter
Hi Trev, Looking very tidy and progressing nicely. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Nem, Thanks for your time looking in,the metal plates take a bit of getting use to but I think you always look for a better result. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Guest (6)
