6 Pages 123>»
Revell 1/72 flower class corvette Options
kpnuts
#1 Posted : 29 December 2014 20:45:37
Hi all ive made a start.
#2 Posted : 29 December 2014 20:55:46
Nice start. It's an unusual style of hull assembly using the 4 sections but works well.
You have done the right thing in clamping tight.
When you consider the age of this kit being an early release from matchbox you gave to admit how fantastic a model it is.
Hope the rest of your build goes well.
#3 Posted : 29 December 2014 23:58:56
Great to see you underway with this one KP, look forward to seeing what you do with this.... will be following as usual.... Cool Cool
#4 Posted : 30 December 2014 00:20:27
kpnuts
#5 Posted : 30 December 2014 21:52:30
Hi all hull halves together
as you can see will need a fair amount of sealant to waterproof it, even though I used a vise the gaps are still quite large. just waiting for the brass rod and tube for the prop shaft to come then I will seal it all.
kpnuts
#6 Posted : 02 January 2015 21:20:36
Installed the prop shaft on the corvette
#7 Posted : 02 January 2015 22:49:01
Coming together nicely Ken,,,, Cool Cool
kpnuts
#8 Posted : 04 January 2015 18:43:44
Hi all got the radio gear in the Corvette today.
kpnuts
#9 Posted : 13 January 2015 18:58:46
Hi all done a bit to the corvette. the strengthening tie bars are a joke they bend all over the place had to add some plasticard to them to stiffen them also number 9 rib is about 1.5 mill too long when in place and you add the top deck it creates a gap all down the side so had to had a bit off that, fits ok now.
kpnuts
#10 Posted : 18 January 2015 20:52:22
well did some filling and glued some deck parts on corvette and added the wooden decking to the rear.
#11 Posted : 19 January 2015 00:23:04
Looking good Ken....Cool Cool
kpnuts
#12 Posted : 23 January 2015 22:02:04
Hi all since my bosses husband is buying the Bentley and my boss has commissioned me to build 2 1/48 Tamiya spits and a 1/48 Tamiya Lancaster (her father was an electrical engineer on the lancaster and actually worked on the Concord too)the corvette is going to have to go on the back burner for a while but here is where I am now on her.
k8 vnl
#13 Posted : 25 January 2015 14:01:16
Doing a good job.I did this about 2 years ago and still have it displayed.It took allot of painting that's for sure.
Built and building
All things Airfix & Revell.
swordfish fairey
#14 Posted : 26 January 2015 11:15:27
Hi Ken, that's coming along very nicely, have you decided what motor to use?........I built one of these a few years ago,(the Matchbox version) and used a Dumas 6 volt Pittman motor(direct drive) and it worked a treat..........It gives a nice scale speed and has a bit of oomph to get out of trouble if needed........I used a 6v, 4.5amps gel battery and with the motor drawing .5amps it would have given a duration of about 8 hours if needed.............They are fun to sail and quite manoeuvrable too, I have placed very well in steering competitions.........Just a couple of things to think about, you have to be careful with top weight, like the originals it tends to roll on wet grass and the camouflage is surprisingly effective out on the water and soon starts to merge into its surroundings,(I've lost sight of mine a few times)..........
Keep up the good work.........Tony
#15 Posted : 26 January 2015 11:25:42
Coming along nicely Kev
Are you going to be sharing your commission builds in a diary?
#16 Posted : 26 January 2015 13:29:06
Looking good. like the replacment hatches.
kpnuts
#17 Posted : 27 January 2015 17:23:47
If anyone is interested I will post a log of my commissioned builds but will just be oob as she wants them to look like they just rolled off the production line, I won't be using pe as they will be hanging and so that detail will be too far away to see. On the plus side of course they won't take so long to build.
#18 Posted : 27 January 2015 18:35:14
Please do, that would be great BigGrin
#19 Posted : 27 January 2015 19:01:22
Yes I would be interested in seeing the builds!!BigGrin
#20 Posted : 28 January 2015 00:11:19
can never et enough builds to brows through BigGrin
6 Pages 123>»
