7 Pages <12345>»
Leopold railway gun Dioramma Options
#41 Posted : 28 January 2015 00:04:21
2 hours!!! how many brews did you have LOL LOL LOL LOL LOL
Looks nicely detailed I fancy this myself but no idea where i would put it lol
keep the picks coming
#42 Posted : 28 January 2015 08:52:24
Hi Jase,
Not enough!!BigGrin BigGrin There were 20 pieces in this bit of chassis alone, and some needed squaring off and the axles in between needed seams sanding. The pain was getting the chassis frame to sit perfectly square, after reading up on the kit, if you dont spend time here, the wheels dont sit on the rails properly and the boiler wont fit. Time well spent!!LOL BigGrin
#43 Posted : 28 January 2015 09:33:54
I agree Daran, setting everything square now will pay dividends later and will ultimately end up saving you time? Nice start mate, looking forward to more. Cool ThumpUp
#44 Posted : 28 January 2015 13:59:05
Hi Jase,
thats the trouble with railway models you need all the wheels perfect, you cant just stick a rock under a wheel and pretend you ment for it to stick in the air like on other vehicles - not that i have ever done thatMellow
#45 Posted : 28 January 2015 14:09:29
Hi Jase,
I dont know what you mean, never done that!!LOL LOL LOL LOL
#46 Posted : 28 January 2015 22:05:07
Managed to do some more to the loco tonight, installed the leaf spring suspension and tie rods. Fairly straight forward, but getting them all perfectly inline was good fun!Cursing LOL BigGrin Let these set 100% before I attempt anything else on the chassis.BigGrin
#47 Posted : 28 January 2015 22:57:17
BigGrin Looks like your having fun
#48 Posted : 29 January 2015 10:29:50
Making good progress already Daran, how does it feel to finally get started on this after having it in your stash for so long - good I'll bet? Cool ThumpUp
#49 Posted : 29 January 2015 11:26:32
Hi Nem, BigGrin
Lots to get straight and level, but coming on nicely.
WTG
#50 Posted : 29 January 2015 11:32:02
Thanks Andy, Kev and Del for looking in, yes Kev it is good to finally get a start on this, although going from 1:16 back to 1:35 is a shock!!!LOL LOL BigGrin
#51 Posted : 30 January 2015 17:29:06
Boiler supports added to the chassis, and the boiler made up. Lots of work to be done on the boiler, seams to sand, gaps to fill and also remove the cast on pipe work so I can replace it with brass and styrene rod. The photo etch kit comes with the clasps to do this upgrade.BigGrin BigGrin BigGrin Dry fitting the boiler to the chassis gives you an idea of the scale of the loco, its a fair size!!LOL BigGrin
#52 Posted : 30 January 2015 18:47:55
Hi Nem, BigGrin
That`s looking good and if that`s a "fair size" I`d hate to see "LARGE".
LOL LOL LOL LOL LOL
Plus, there was you saying going from 1:16 to 1:35 was "a shock", well me thinks you would have seriously struggled doing this in 1:16.
For sure you would have needed a railway siding.Huh
Looking forward to the detailing session.Cool
#53 Posted : 30 January 2015 19:15:24
Hi Derek and thanks for looking in. Theres me thinking getting back to something that fits my work space is great, and I decide to do a 6 foot dio!!LOL LOL LOL It is a really nice kit, and my first ever loco, or anything to do with rails for that matter!!LOL BigGrin BigGrin Just ordered some styrene rod and some brass rod soI can make pipes and valves.BigGrin
#54 Posted : 30 January 2015 19:25:47
BigGrin Looks a nice engine and any additions can only improve her looksCool
#55 Posted : 30 January 2015 21:23:39
Couldn't resist, so I assembled some of the tender! Took 20 minutes including a brew!!LOL LOL LOL BigGrin BigGrin
#56 Posted : 30 January 2015 22:14:34
Blimey, that really is going to be MASSIVE Blink good work so far
#57 Posted : 31 January 2015 08:39:27
Nice work Daran, she looks an impressive model already and you're certainly cracking on with this build my friend - well done!! Cool ThumpUp
#58 Posted : 31 January 2015 18:19:14
Started on the front cross member and buffers. The kit parts were not to scale and were not very detailed so I found some replacements in turned brass.BigGrin
The buffers are a bit over the top for a static model as they are fully functional, but they do look the part!!
First to remove the original mounts from the cross member.
Then glue in place the new mounting plate.
Buffers done and the complete cross member fitted to the chassis. They look so much better!!BigGrin BigGrin
#59 Posted : 31 January 2015 19:38:08
BigGrin Very nice addition and your right they do look much betterCool
#60 Posted : 31 January 2015 22:43:39
I agree they do look much better Daran, a nice upgrade!! Cool ThumpUp
Question: Do they supply replacement nuts and bolts to add to those brass plates - the buffers look fantastic but the new plates don't really look authentic with a few circular indents where the bolts should be? If not then you could always slice off the plastic ones from the original kit buffers and glue them onto the indents in the brass ones?
Nice work my friend. ThumpUp
7 Pages <12345>»
This page was generated in 0.358 seconds.
