launch planking Options
comtechy
#1 Posted : 30 August 2010 21:55:03
i wonder if u guys could help me im doing pretty well with the build so far im just having a nightmare with the launch planking ive managed to do the 2 planks either side of it but ive tried and tried to do the 2 tops ones with no success i cant see what angle they have to be cut etc ive stopped the launch its driving me nuts ive even tried to google a template
please help
riff-raff
#2 Posted : 30 August 2010 22:17:25
Hi Comtechy
Not sure which two planks you mean but:
Take your time with each plank and treat each plank as an individual job.
Lay the plank from the rear of the launch to the front and mark the overlap as best you can.
Remove only a little at a time and test fit. Do this until the plank lays in the correct position.
Do this for each remaining plank.
If you can post images with your problems then please do so, it makes it easier to help.
Have a look at others build dairies as well as others have similar problems and a solution can often be found by reading others experiences.
Hope this helps BigGrin
Built:
Mike Turpin
#3 Posted : 31 August 2010 00:28:11
If you go to the Tutorials section of Model Space, you will see a link to my build log for the launch which quite a few members were kind enough to say they found useful.
Mike T
This page was generated in 0.033 seconds.
