Andreas Hummer H1 (The Third) with optimized Chassis Options
Andreas
#1 Posted : 31 January 2015 13:38:19
Groups: registriert
Hi Folks
This is now my third Hummer H1 chassis, and the last I hope.BigGrin With this Chassis I want to see what is possible to do with the Hummer H1 Body. My plan is that all doors, the hood and the tailgate should be possible to open and close. The chassis will get a nice flip flop painting. The color will be red into gold. For somebody who doesn’t know the Flip Flop color, it changes its color from Red into gold when you turn the Chassis in the Light or sun. I already did it by the second Hummer H1 Body. There the color changes from Blue into violet. There will also be installed door seals, as in the original. In the hood. I 'm going to install a diorama from the Hummer H1 original Engine under the bonnet The same at the Tailgates. So if you open the bonnet you will see a Hummer H1 engine. The Chassis also includes all lighting systems. Some tags are already made, below some results so far.
Best Regards Andreas
Forum Support Team
#2 Posted : 31 January 2015 13:56:59
I really like your NATO Hummer and am looking forward to seeing how your paint work turns out. Judging by the finish on your other Hummer I think this will be really cool
This page was generated in 0.089 seconds.
