Sinbad Options
Sinbad
#1 Posted : 31 January 2015 23:35:00
Turquoise Medal: Turquoise Medal for model making know-how contribution
I've been away for some 9 months mainly for personal reasons which were affecting my Victory build. I'm back now with a clear head and raring to go.
I must say that this build diary frm Malaysia is the most informative I've seen and, I feel, is even better than the 'Official' one. One picture is worth a thousand words.
http://forum.model-space...posts&t=6380&p=2
#2 Posted : 01 February 2015 00:15:40
BigGrin Welcome back and will be awaiting your next build diary entryCool
Sinbad
#3 Posted : 02 February 2015 14:53:10
Not to sure about a build diary. I'll make the occasional comment.
I started the planking at the stern and was surprised I had none break on me. I must say though that some of the wood 'splintered' a little on the initial bend,that's the best way I can describe it. Nothing a little sanding won't hide.
#4 Posted : 02 February 2015 15:51:54
Welcome back SinbadBigGrin
Nice to see you are back on the Victory. With regard to your stern planks splintering, did you soak them first before bending them? I don't recall any trouble in this area after they had a long soak in warm water, and perhaps a little steam to pre-shape them.
Sinbad
#5 Posted : 03 February 2015 21:44:06
Yes, I soak them in hot water. I've tried cutting down the soaking time to see if that helps. If that doesn't do the trick I may try bending against the grain.
#6 Posted : 04 February 2015 00:01:59
As steve says a good soak in hot water should do the trick. what is your method of forming the bend?
The method I used was to soak in hot water then apply heat to the inside of the curve while forming the bend. I used a soldering iron to add the heat and gently applied pressure on a flat surface to form the bend.
Another method i have used is to hold the strip over a boiling kettle and apply pressure to form the bend while in the steam - works well but is less controlled than the above method.
but you should also be able to do it with the crimper tool see video below
https://www.youtube.com/watch?v=N-FJQZlLMhU
Hope that helps
Sinbad
#7 Posted : 04 February 2015 21:17:29
Hi Jase
Seems great minds think alike. BigGrin Like you I use a soldering iron.I use ever so gentle movements to get the initial curve. I've just found what I can do that helps is while the end of the plank is still pliable I temporarily pin it along it's length and then follow the natural curve created by the rib. I then leave it to thoroughly dry and then it's just a matter of doing some fine adjustments and glueing. Seem to work so far.
#8 Posted : 04 February 2015 21:41:36
Sinbad wrote:
Hi Jase
I did the rubbing strikes on my San Fran that way but with tape rather than pins. it helps maintain the curve as it dries rather than shrinking back a bit.
#9 Posted : 04 February 2015 21:41:36
Sinbad wrote:
Hi Jase
This page was generated in 0.060 seconds.
