Joined: 04/04/2013 Posts: 89 Points: 270 Location: Stroud, Gloucestershire
this is not a build log as have only just joined the forum so just a few pics as to where im at have been asked to post them here regards all Ant antswain attached the following image(s): Current builds :
AL's HMS Surprise Model Shipyards HM Cutter Mermaid
Very nice Ant, lovely finish on that hull too Steve
Very clear pictures. And a very nice build, you have got a great finish on the hull!!
Nice work Ant, and congrat's on your first medal
 The hull looks a treat and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 06/05/2010 Posts: 233 Points: 708 Location: Leigh on Sea
Tried to post a link to Magpies Surprise build which was very good and innovative ....but failed was not a hyper link ...ah well ...I recommend having a look Ant....Dave C H.M.S Victory H.M.S Victory X Section H.M.S Surprise under the bench D-51
Hi Ant  . Welcome to the best forum on the planet. Your hull looks great and you have done a great job. Best regards. Mark
Looking great Ant, your efforts are really paying off.... Regards Alan
thanks for the kind comments guys - I have looked at Magpies build so clean and precise if I get a quarter as good id be happy = but still reasonably pleased with what ive done on my first build - that rigging looks daunting tho Ant Current builds :
Hi Ant, I really like this kit and you`re doing a fine job on it. I`m collecting this for a build at a later date myself, so keep it coming and congrats on your fist medal of many. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 09/02/2012 Posts: 569 Points: 1,675 Location: Scotland
good looking build you got going there. Hope all goes well.
Mo. Mo
thanks Mo Been doing the blocks for the cannons as u know what an eyesore that one is! looked at your build several times for pointers excellent job uve done are you continuing with It? regards Ant Current builds :
A very fine looking build you have. hull finish is fab jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
antswain wrote:thanks Mo Been doing the blocks for the cannons as u know what an eyesore that one is! looked at your build several times for pointers excellent job uve done are you continuing with It? regards Ant hope to get back to it later this year, moved house and not stopped working on it, really missing my build, Mo Mo
Hi all just a few more pics to show what im at - been working on upper deck furnishings,finishing launch and cannon blocks. Lower deck chain pumps built from scratch but have housed this on mahogany strips as fiddley. also on with masts and mast heads and bowsprit one question  - how do you fit the rings to the top of the cannons to take the thick restraining rope ca glue dosent seem to work keep falling off Ant antswain attached the following image(s): Current builds :
Looking great Ant, some very nice scratch building there.... well done....  .. Regards Alan
been working on the cannon rigging fiddley little blighters but movin on Ant antswain attached the following image(s): Current builds :
Hi Ant, Coming on well and a good idea on how to stop the cannon rigging ending up like a birds nest. Keep it coming Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Looking good J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Ant, fully rigging the cannons is a very fiddly process but I believe it is very much worth the effort as can be seen with yours.... Lovely work and very nicely done.... Regards Alan
Guest (9)
