2 Pages <12
Rib 15 Your Input please Options
riff-raff
#21 Posted : 31 August 2010 14:13:32
On Rib 15 yes mate - they will need to be build up buy 1-2mm but the fix should bring everything back together once the decking and planking is completed the fix should be completely invisble.
Built:
riff-raff
#22 Posted : 01 September 2010 15:35:28
It does alter the angle of the deck supports but only on rib 15. Mine are now approx 1.2mm lower than those on ribs 14 and 16.
I realise that the top deck support may be visible (can anyone confirm???) if that is the case then there may be another issue later on once the planking is complete. If it is visible then I may remove the top of 15 in a similar way as I did before.
Doing this should not alter the integral strength of the hull but will bring all parts back in line on the completed model.
I think I shoud have built a plane instead - the amount of winging it I am doing here Confused Confused
Built:
darrenallen
#23 Posted : 01 September 2010 15:43:28
As many people are so far down the build it is unlikely that a replacement part 15 is going to be much use.
However, it might be a good idea for admin/deagostini to issue a lifesize template of the correct shape of the part. That way the people who haven't fitted part 15 will be able to make fairly easy adjustments and also the template can be cut/folded for the ones already fitted into the hull.
Just think it will make life a little easier for all.
As it stands I haven't fitted mine yet as waiting for more parts, but really not looking to mod the part without any official guidance. I'm not that good a model-maker yet :-)
Just a suggestion.
benny
#24 Posted : 01 September 2010 19:46:22
hi all is it just my boat but is the top of rib 27 sticking out too and one side of rib 20 seems to be larger than its opposite side...apologies if its been mentioned b4
cheers benny
#25 Posted : 01 September 2010 20:22:08
Just checked mine Benny and its okay mate...Mellow
RussG
#26 Posted : 02 September 2010 00:15:21
Mine seem to be OK, but time will tell when we come to the planking !!!!!!!!!!!! But a great fix, thinks that I would do!!!!!!! BigGrin
Happy Building, Russ
Deepseacodmaster
#27 Posted : 24 June 2011 19:30:40
Lonestar Spirit wrote:
I dont think this is a DeAgostini issue, this is obviously a manufacturing issue, if an issue at all (which it definitely looks like)as rib 15a on my model is ok yet 15b is definitely not in alignment with the rest and protrudes out from former 14b and 16b by 2.8mm, I was going to try and pull the rib in using a strap, but this will effect part 15a which is ok, so we might have to resort to riff raff's method, but before I do anything that drastic, I think DeAgostini should get in touch with the manufacturer and get some answers as to whats going on, is the part defective, how do we solve this issue etc, but also some assurances that if this is a mistake, how do we stop it happening again!
Hi All
Does anybody know or able to confirm that the machining problems with rib 15 have been corrested.
Since my build is a recently issued edition I have not found any problems
Just want to know for my own peace of mind BigGrin BigGrin BigGrin
First Build HMS Victory and HMS Endeavour
Also Krick steam boat "Victoria"
Cheers
Ivan (Ordinary Seaman)
http://www.old-glossop.com
#28 Posted : 24 June 2011 21:14:26
Hi Deepseacodmaster...I think they may have corrected the problems with rib 15 a good while back...none of the newer members to this build have mentioned any faults as far as I know? Happy building mate.
BigGrin
budgie
#29 Posted : 24 June 2011 21:41:32
BigGrin
BigGrin agree with u there Johnny
BigGrin i like to think that Deag in general listen to our gripes and groans relevant to the build & try to rectitfy any short comings with the 1st subscribers
Like i have always said "1st time ever build of Victory by Deag" make mistakes rectify them but takes time
maybe now is the time to subscribe to Build the Victory
ps "is the cheque in the post"LOL
Deepseacodmaster
#30 Posted : 24 June 2011 23:35:39
Thanks for the info lads
My old mind (adled with beer,sex and nicotine) is now at peace
Mad Mad Mad
Cheers
Blackspear
#31 Posted : 25 June 2011 08:20:08
Ack! saw this post and paranoia immediately set in and I rushed out to the shed in the pouring rain to check my ribs. I have just completed planking the upper hull and was about to start planking the lower hull ( a part I am really not looking forward to as this is my very first wooden build). If there was a problem with rib 15, it seems that the planking has corrected it as mine are totally in line. Maybe Tomick could jump in here and confirm that the planking has the effect of lining it up? or is this an effect that has developed over a period of time with the manufacture of rib 15 and I have been lucky and got mine before the problem arose... anyone got any thoughts?
Atholm
#32 Posted : 25 June 2011 12:18:28
Hi Deepseacodmaster
I found that bottom of rib 15 did not finish flush with the bottom of the false keel. I had to increase the slot in rib 15 by approx. 1,5mm.
Enjoy the build
Athol
Deepseacodmaster
#33 Posted : 25 June 2011 13:04:25
Atholm wrote:
Hi Deepseacodmaster
Enjoy the build
Athol
Thanks Athol
Mine is the same so I will open up the slot a touch.
By the way Durban is my second most favorite world city after Frisco California.
Always had a good time there. BigGrin BigGrin
Cheers
Atholm
#34 Posted : 27 June 2011 17:10:11
Hi Ivan
Glad I could help
Happy building
Athol
2 Pages <12
This page was generated in 0.191 seconds.
