Hi all, thanks for the nice comments. Happy new year too all. Here are a couple of pictures of the the Hood. Slowly getting there. magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
She certainly is coming together Chris, lovely work..... Regards Alan
Hi all, Thanks Alan. Here are my upto date pics....magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Nice to see a Hood build still going, and it is coming along very nicely indeed!
Hi Chris, she certainly is looking great and this will be a diary I will be referring to when I eventually get started on my own build....  .. Keep posting those great pics as you have one avid follower here...  Regards Alan
Looking good Chris, should be a fantastic display when complete Steve
remind me, how many ready use ammunition lockers are their on the Hoods deck? enjoy can't wait to see the upper works taking shape J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Thanks guys, really appreciate your nice comments. Here are pics of the propeller shafts. Chris...magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Chris, very smooth and neat - can see you have put a lot of time and patience into getting this one to look so good. Very well done. Happy Modelling
What a difference a coat of primer makes!  Nice even coat and you can tell you have spent the time with shaping of the hull, not a sigle plank shows, you can't even see it is wood. Top work, I wish I had that patience and skill with wood builds.
Hi Guys, Sorry for the delay in update. I bought vallejo model air "hull Red" sprayed it and found it more brown, look at pic 1.. So after few days in between work , worked out what cross reference I needed from Rn19. I bought Model masters crimson red. So much more like red oxide now. This was my first time airbrushing Enamel and thought it quite eash. Only problem i have is Overspray in areas. If i flat it down it gets a sheen. Should I get an Acrylic(Alcad Flat Laquer or Vallejo Flat) and give it a go over them flat it and another coat.. Please advise. Thanks Chris...magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Coming along a treat Chris, lovely work... Regards Alan
Hi Chris. You have done an awesome job on the hood  . I look forward to seeing more. Best regards. Mark
Hi Chris colour looks spot on. if it was me i would go with a Vallejo acrylic matt varnish now. hull look perfect, blemish free - top job Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Cheers guys, Thanks for the nice comments and help with my dilemma. Here I have fitted the rear deck and filled and sanded. Looks more like a ship now than a lump of wood.Cheers....magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Looking good, steady as she goes as they say..
Hi all, Today I have installed the second deck and fitted the brass decking plates. They've had a white undercoat. Instructions say paint before fit but I thought I'd get a better finish painting on.. Thanks Chris.magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Really impressed with this build Chris, very nice work indeed... Regards Alan
Guest (11)
