Which primer? Options
WildRover
#1 Posted : 08 February 2015 01:49:14
Hi guys, just after finding out if there is a preferred primer (ordered lifecolour aotake for paint) that can be sourced in the uk?As I plan on building it half skeleton, and only portions of it in the aotake, so a lot will be "clear coated"
If not, what should i be looking for on primer, other than being suitable for metal and clearBigGrin Is there anything i need to avoid if im airbrushing onto the primer, as my process will be white vinegar wash, then rinsed with water prior to primer application.
Completed: Earth, Moon, Sun Orbiter
Build a Model Solar System
Under Constuction: HMB Endeavour
HMS Victory
Mitsubishi Zero
Tiger Tank
D51
#2 Posted : 08 February 2015 02:33:47
BigGrin Hi WR
Some info here on primers
http://forum.model-space...aspx?g=posts&t=3446
also on flee-bay
http://www.ebay.co.uk/it...amp;hash=item3cd30d23db
I think there is a supplier in the UK now but have misplaced the link, I will update tomorrow when i have found it.
If your painting the model and not having the bare metal finish then Halfords Primers or any good brand will do fine. I will add that I have clear primed before adding Aotake to the parts but have also omitted it when I ran out, whilst awaiting the next consignment from the posty and have had no problems with the Aotake paint adhesion after a good degreasing.
#3 Posted : 08 February 2015 10:52:38
BigGrin Hi WR
The supplier for a clear undercoat is in the link below, its not Tamiya but Mr Gunze which some say is a better product.
http://www.modeldesignco...Spray%20%20%20UK%20only
#4 Posted : 08 February 2015 11:10:19
The dark art of primers!!LOL LOL I use a variety of primers, depending on what I am building, and also what scale. My prefered weapon of choice is the Vallejo range. It comes in a wide range of colours to help with your top coat colour, and is pre mixed for airbrushes. It is self leveling and its coverage is superb, it goes for miles!!LOL BigGrin It works well with all paint manufacturers, Tamiya etc, and will cover everything from metal and resin to plastic and rubber. I also use automotive primers. Simoniz or Hycote are great in a can for large pieces. If you see my Hachette Tiger or my current T34/85, they are done with rattle cans. Lots of light even coats. The white on the interior of the T34/85 is white Simoniz primer, and was excellent to work with. Everyone has there own preference, my choices may not be others. It all depends on what works best for you. I tend to stick with what works best for me.BigGrin BigGrin
WildRover
#5 Posted : 08 February 2015 11:37:18
Thanks Andy and Nem Cool - looks like im shopping today then!
HMS Victory
Mitsubishi Zero
Tiger Tank
D51
WildRover
#6 Posted : 08 February 2015 15:56:35
another daft question - if i'm not painting the skeleton half, to prevent dulling, is the primer sufficient, or should i get a proper lacquer?
HMS Victory
Mitsubishi Zero
Tiger Tank
D51
#7 Posted : 08 February 2015 16:08:21
BigGrin The primer should do just fineCool
WildRover
#8 Posted : 15 February 2015 18:06:44
Is this stuff suitable? its a clear etch primer
http://www.amazon.co.uk/...sol-Spray/dp/B004SNDADO
Got all my other paints, bar a gunmetal which i need to go to my LMS for, so with any luck a build diry will be started next week or so!
HMS Victory
Mitsubishi Zero
Tiger Tank
D51
#9 Posted : 15 February 2015 19:00:19
Hi WR
I would stick to the Mr Gunze clear undercoat as that stuff needs specialist items like an air breathing system and a sealed spray booth to apply it as its highly dangerous to your health to use it without these pieces of equipment.
experten
#10 Posted : 17 February 2015 05:02:33
Groups: Registered, Official Builds
Mine is done exclusively with Tamiya clear primer. It is noxious, but manageable. I also used Lifecolor Aotake,and had no problems.
Tired, Old, and Cranky!
This page was generated in 0.137 seconds.
