The subscription length is 24 months and the monthly cost is £34.99/€39.99 including FREE postage and packaging.
After you have received the first components of your first pack, you will receive the next pack containing your next set of components two months later, with a one month gap in between. We will skip a delivery every other month to give you the time to build your model and charge your account monthly to make it more affordable.
Each delivery will contain a magazine with step-by-step instructions on how to complete the next stage of your model.Tomick attached the following image(s):
 Rank: Amateur Level 1  Groups: Registered
Joined: 07/04/2011 Posts: 37 Points: 100 Location: ballymena
Great news, makes this viable now, is there any plan to do this with the 3d printer, i have subscribed to it but second guessing whether i can afford that every month
Yes, hoping to offer similar for the 3D Printer
Can we convert from 12 to 24 if this does happen if we are already signed up or just cancel and start again?
Yes you can convert from 12 to 24
As soon as the 24 month option is showing on the Drone order page you can then ask c/s to make the change.
But don't forget that if you convert to 24, you won't then receive a Drone pack every month and the build time be twice as long.
 Rank: Semi-Pro Level 1   Groups: Registered
Joined: 22/01/2015 Posts: 72 Points: 230 Location: Poole, Dorset, UK
Just ordered the Sky Rider Drone, and Part 1 has arrived - this is my first model since Airfix and Revell when I was a kid. Having said that I am extremely excited both to make the kit and to eventually fly it. Got my eye on HMS Victory also. Marsot ______________________________________________________________________________________________ Building: Sky Drone, HMS Victory, Mary Rose Wishlist: Spitfire http://www.sotheran.com
Welcome to Modelspace Marsot  Be good to see your drone build diary on here, and the Victory for that matter Steve
