gun ports Options
rich11
#1 Posted : 14 February 2015 15:26:41
Hi where can I find some sample picture or measurement explanation ,how to measure and cut gun port holes on ship .I have no idea of sizes and locations of gun ports. Thanks .
#2 Posted : 14 February 2015 21:27:27
Hi Rich and a warm welcome to the forum... All of the information you need to mark out the gun ports starts with issue 35. Would also recommend you look at Mr T's official diary. In addition, page 40 onwards on my diary also shows how I went about marking and cutting out the gun ports and would suggest you have a look through this.... Should you still have concerns then please get back to me....Cool Cool .. Have provided a link to the relevant section on my diary....
http://forum.model-space...sts&t=5013&p=40
Hope this helps..
rich11
#3 Posted : 15 February 2015 12:26:56
I can't find that Mr T
#4 Posted : 15 February 2015 12:34:33
rich11
#5 Posted : 15 February 2015 13:49:25
thanks mate.maybe you can post for me pictures for issue 35...thanks .
#6 Posted : 15 February 2015 14:06:31
Issue 35 shows all you need, mark out the model for the port placements as shown in the instructions. The measurements are indentical on both sides of the model as is the positioning of the gun ports and entry ports.
Double check your port measurements and the positioning of each port in relation to the magazine step images BEFORE you cut-out each port. Each port should be 13mm wide and 12mm tall.
Note that step 13 shows the positioning of the port to the right of frame 16 to be 15mm aft, and the port look almost central between frame 16 and 20, which is also reflected in later step images of appearing almost central between the two ports above as shown at step 16. However, you may find that the 15mm measurement at step 13 should be closer to 20mm for the port to appear almost central between frames 16 & 20. Subsequent magazine images show this port to be almost central.
rich11
#7 Posted : 15 February 2015 14:35:37
ok thanks
This page was generated in 0.340 seconds.
