This is a little in between build I have had for a while and needs finishing! (along with 3 others! ) Its the Tamiya kit with a few extras, and its a nice break from the Loco, which is a very intense build, and is going together well.
Another nice kit choice, looking forward to your progress “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
A quick up date. Photo etch pedals done, gear levers etc. and seats. There are pe dials and facia on the center console, but they will be fitted after painting. All dry fit as it will be painted and weathered in 3 parts, chassis, floor pan and body. Sagged wheels are brill, shame they dont do a set for the field gun!
Nice kit, the PE will lift it and the resin tyres look great. Another to look forward seeing the end result of
Thanks Tomick, its usual Tamiya standard, so really nice to put together and the pe sets just kick it up a notch. I really like the detail on the resin wheels, Firestone tyres no less!!
 Hi Nem Funnily enough I recently got this kit for £12 off flea-bay and got the same etch and tyres you have. Im still deciding to use this kit or another I have as my next dio. Looking good so far, Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Hi Nem Funnily enough I recently got this kit for £12 off flea-bay and got the same etch and tyres you have. Im still deciding to use this kit or another I have as my next dio. Looking good so far, Regards Andy This would make a fantastic dio, go for it!!
I too have exactly the same kit and both sets of etch - this is obviously a very popular model!!
I look forward to watching your skills turn this into another great build Daran - nice one!!
Kev
Me too  Built them on here last year. Yours is looking good, like the wheels Steve
Hi Nem  . I am so looking forward to seeing your build come to life in your expert hands. Best regards. Mark
Thanks for looking in and the comments everyone, being a quickish build I wont be using all the etch, but more on the weathering side for desert conditions.
I don't have it Have been toying with the Accurate Armour kit so intrested to see your end result J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 27/06/2011 Posts: 437 Points: 1,321 Location: milton keynes
Snuck this one in Nem only just come across it looking great so far Regards dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Being as I have a ton of primer work coming up I though I would get this done. Building is done, just a few tools to add and some stowage. I like the way the sag tires sit and they have a proper tread pattern and rotation direction. The barrel looks superb. Really happy so far. Nemesis attached the following image(s):
Nice to see you back working on this one Nem, no doubt another fab display piece being produced.... Look forward to seeing how if finishes.... Regards Alan
Nice work Nem  i always liked the Quad but have never made a big one, maybe I should Al
Looking good Nemesis, those resin tyres do look rather nice
Nice work as usual Daran, gonna look very cool when it's painted and weathered - well done!!
Kev
Had a bit of a primer frenzy and this was one of the victims! Nemesis attached the following image(s):
looks great.I know that feeling when you get a full can of primer out and you see all those unfinished models that got to the primer stage and just go nuts spraying everything.
