6 Pages «<3456>
Build Diary of Amati 1/200 Bismarck Options
B Johnson
#81 Posted : 07 September 2014 16:56:22
Started working on the 20mm guns, quad and single, so far I have completed 3 of the single guns as these take some patience and time to build, upgrade parts from the MK1 set have been used.
Current Builds: Amati 1/200 Bismarck, Airfoil 1/600 HMS Nelson
To Build: Amati 1/200 HMS Hood, Amati 1/250 Titanic, Artesania Latina 1/48 HMS Surprise, Artesania Latina 1/50 Scottish Maid, DeAgostini 1/84 Sovereign of the Seas
#82 Posted : 07 September 2014 17:45:46
Ben
That really is a very top build you have there. Well impressed how your getting you etch to stik to plastic/resin without (in macro mode) great globs of super glue showing.
My eyes really are suffering (to manybyears working for accompany that has use working 12 hour days off laptops before any of you startvgettingvyour own ideas LOL )
Just invested in a full optivisor goggles from Shesto - cheaper than wasting money at opticians in my view. Bit worried though that the case it came in is a hand gun storage box Confused .
Very lovely build.
I would be very interested to hear how you apply cyno glue - I use a cocktail stick but it still looks like it's been poured on
B Johnson
#83 Posted : 07 September 2014 21:03:28
birdaj2 wrote:
Ben
Very lovely build.
Thanks Tony,
Yeah I sometimes struggle with applying the glue, at the moment the glue i'm using comes with a brush applicator, using this is quite precise. In the past applying a little glue to the smallest part to be glued can also work, so for examle, applying the glue to the end of the barrel instead of applying it to the resin/plastic part first.
Ben
#84 Posted : 07 September 2014 23:51:01
Lovely work with the etch Ben, efforts are paying off.... Hope its not affecting your eyesight too much... BigGrin BigGrin .. Really impressed with this build....
B Johnson
#85 Posted : 10 September 2014 20:15:49
Thanks Alan, yeah the eyesight is good thankfully, need it with this kind of work!
#86 Posted : 10 September 2014 20:22:17
Wow that is seriously impressive PE work. I just hope I can do as good a job on my Yamato 25mm's when I get to them
Keep up the great job ThumpUp
B Johnson
#87 Posted : 12 September 2014 20:01:36
Thanks Dave, at least i'm working in a larger scale, it must be a nightmare at 1/350! However i've seen your build so far and the PE work is amazing.
Ben
B Johnson
#88 Posted : 14 February 2015 17:17:42
Its been a while and its very slow progress but here are some updates
some work on the upper superstructure, added a couple of vents as these were missing from the kit, I have also sanded any rough edges ready for priming
I've added the MK1 barrels and blast bags to the 15cm guns
i've also used the MK1 barrels for the 10.5cm guns along with the extra photo etch supplied in the upgrade
Work on the rangefinders, again I will be upgrading these with aftermarket etch.
so this is the ship as it stands, looks as if its getting there but still got loads to do. Most of the major components are now complete, I just have the small detail and components to work on.
#89 Posted : 14 February 2015 17:24:38
Some serious metal work going on!! Very nice indeed!!!BigGrin BigGrin
#90 Posted : 14 February 2015 17:56:56
Excellent work Ben, she looks great Cool
#91 Posted : 14 February 2015 18:50:55
BigGrin Looking good, i must get round to starting my Trumpeter Bismark soonCool
#92 Posted : 14 February 2015 20:09:31
B Johnson
#93 Posted : 15 February 2015 09:11:42
Thanks for the comments guys
Ben
B Johnson
#94 Posted : 13 January 2016 20:20:08
It's been a while and i've had very little time to spend on the model so very slow progress.
I've managed to make a start on the forward superstructures baltic stripe, very hard to achieve the stripe all the way up, areas had to be masked then re-masked several times and the process was very time consumming. I was worried there would be some paint leakage once the structure was airbrushed but thankfully this was very minimal.
I've also started to work on some of the smaller ships fittings. I upgraded the searchlights with the Eduard photoetch, because of the size of some of these parts it was very tricky to apply it. I've put together the 20mm anti aircraft guns again adding photoetch, using the MK1 barrels and some slight alterations by applying plastic card.
#95 Posted : 13 January 2016 20:33:56
#96 Posted : 13 January 2016 21:03:44
Lovely looking model and extremely well painted.
#97 Posted : 13 January 2016 21:26:18
Spot on with the paint work, looks fantastic!!BigGrin
michael.rolph
#98 Posted : 13 January 2016 21:36:11
Wow some of that etch is tiny.
I'm going to have to carefully read your build log and see if I can pick up any tips to help me with the battleship i'm about to start
#99 Posted : 13 January 2016 22:24:18
Great to see more progress on this and fantastic job on the masking, that looked like a nightmare but has paid off with excellent results.
Love all the tiny PE work on show too, I know the patience that goes into all that Blink it looks extremely well done a consistent, top job ThumpUp ThumpUp
#100 Posted : 14 January 2016 01:04:20
Very tasty work, think you've done a superb job with painting. If I can replicate that then I'll be a happy chappy......Drool Drool .. Very well done....Cool Cool
6 Pages «<3456>
This page was generated in 0.256 seconds.
