Hi all bet no one knows where this is going.   Ken's the name modeling's the game.
In the fruit bowl ..... between the apples and pears?
Kev
Hope this helps with where its going.    Ken's the name modeling's the game.
Nice one, a minion in an F18, you must have some really good dreams
Mustn't let the missus see this, she'll want one.....  .. She loves the minions.... Nobody tell please,,,,, Regards Alan
Well I am cross I masked this up and sprayed it and the paint has seeped under the masking.    Ken's the name modeling's the game.
Thats a shame Ken, not the end of the world though  , everything can be fixed! Did you use a good quality masking tape? If so then you might also try to seal the tape either with the same colour as you are covering or a clear varnish (matt), and then spray the colour on top of that when dry. There should be no leaks then as the "leaking" will have been done either by the same base colour or the varnish. Also, if you spray multiple very light layers then there wont be any paint able to run Steve
Stevie I used Tamiya tape then normal masking tape, the Tamiya seemed to work I think it's the normal masking tape which let me down. Great tip though thanks. Ken's the name modeling's the game.
Hi all here is an update on this one    Ken's the name modeling's the game.
well after cleaning out my cave look what I found in my stash   with my new supply of milliput you can expect minions galore. Ken's the name modeling's the game.
look what else I found in the stash  Ken's the name modeling's the game.
Hi all well I got some milliput never tried it before but here is my first attempt at a few minions  Ken's the name modeling's the game.
