Revell 1/48 F/A 18C Hornet Options
kpnuts
#1 Posted : 17 February 2015 21:41:22
Hi all bet no one knows where this is going.
#2 Posted : 17 February 2015 22:05:22
In the fruit bowl ..... between the apples and pears? Blink Huh Confused LOL
kpnuts
#3 Posted : 18 February 2015 21:48:33
Hope this helps with where its going.
#4 Posted : 18 February 2015 22:19:08
Nice one, a minion in an F18, you must have some really good dreams BigGrin
#5 Posted : 18 February 2015 23:12:54
Mustn't let the missus see this, she'll want one.....BigGrin BigGrin .. She loves the minions.... Nobody tell please,,,,,Blink Blink Blink Blink
kpnuts
#6 Posted : 20 February 2015 21:25:14
Well I am cross I masked this up and sprayed it and the paint has seeped under the masking.
#7 Posted : 20 February 2015 21:30:27
Thats a shame Ken, not the end of the world thoughBigGrin, everything can be fixed!
Did you use a good quality masking tape?
If so then you might also try to seal the tape either with the same colour as you are covering or a clear varnish (matt), and then spray the colour on top of that when dry. There should be no leaks then as the "leaking" will have been done either by the same base colour or the varnish.
Also, if you spray multiple very light layers then there wont be any paint able to run
kpnuts
#8 Posted : 20 February 2015 21:55:18
Stevie I used Tamiya tape then normal masking tape, the Tamiya seemed to work I think it's the normal masking tape which let me down. Great tip though thanks.
kpnuts
#9 Posted : 22 February 2015 17:37:59
Hi all well i've corrected the paintwork
kpnuts
#10 Posted : 24 April 2015 20:54:17
Hi all here is tonight bit (planes really are not my thing once I've finished this and the lanc and 109 I think they will be my last)
kpnuts
#11 Posted : 26 April 2015 16:06:40
Hi all here is an update on this one
kpnuts
#12 Posted : 25 June 2015 21:26:11
well after cleaning out my cave look what I found in my stash
with my new supply of milliput you can expect minions galore.
kpnuts
#13 Posted : 26 June 2015 20:16:46
look what else I found in the stash
kpnuts
#14 Posted : 27 June 2015 19:30:25
Hi all well I got some milliput never tried it before but here is my first attempt at a few minions
This page was generated in 0.134 seconds.
