15 Pages «<45678>»
steve's build Options
Steve279021
#101 Posted : 12 February 2015 22:47:42
Had a bash at them tonight and they are a nightmare! I managed to snap of the end of the solenoid so I had to glue it, just hoping it will hold. Did you use glue to hold them on and if so what glue did you use?
Dodge charger build complete
ian2014
#102 Posted : 12 February 2015 23:04:00
Steve have a closer look at my hose one bit is glued.
Facebook-model maker
Steve279021
#103 Posted : 12 February 2015 23:57:53
I bet it was the same one I snapped. It was the lowest one that comes off at an angle, the last of the 4 hoses to put on?
ian2014
#104 Posted : 13 February 2015 08:07:59
That's the one hope it does not cause problems later.
Steve279021
#105 Posted : 15 February 2015 23:12:18
Stage 32 done now. Left rear brakes and right side pod hoses done, after a bit of swearing!
ian2014
#106 Posted : 16 February 2015 12:02:50
Looking good Steve I bet it was a lot is swearing lol
DaDokta
#107 Posted : 16 February 2015 17:35:06
Looking good, Steve!
Actually i wanted to build this stage this evening.
Reading all the comments about the hoses i wonder if i should watch tv with my wife instead :)
DaDokta
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Steve279021
#108 Posted : 16 February 2015 19:12:25
Ian, your right, there was a lot! Dadokta, yes I'd wait until you're in a brave mood! Glad I got it out of the way although there is more to come I think.
davidyat
#109 Posted : 19 February 2015 18:15:21
davidyat here. I just finished the 8th packet and noticed you've done pack 9 and 10. Seeing the talk about putting on the hoses and snapping of plastic parts, and before I make the same mistake, are the hoses made out of rubber or soft plastic? If so, do you think soaking the ends of the tubes in hot water to soften them up make it easier to install and NOT have the prospect of snapping off plastic parts?
Dave
Steve279021
#110 Posted : 19 February 2015 18:36:24
Ians idea of holding the ends against the radiator helped a bit. I think my problem was my modelling inexperience didn't help. Other people found it quite easy so it's probably more down to the individual.
Steve279021
#111 Posted : 19 February 2015 22:48:05
Stage 33 done now. Left rear hub/axle/brake assembly.
Steve279021
#112 Posted : 20 February 2015 21:54:20
That's stage 34 and pack 10 done now. So at the halfway stage now.......
Steve279021
#113 Posted : 20 February 2015 22:05:08
.......so that calls for a halfway stage parts put together!
that's it until pack 11 now. Might be tempted to start my mp4/23 whilst I'm waiting!
DaDokta
#114 Posted : 21 February 2015 11:45:28
Nice pics, Steve!
DaDokta
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Steve279021
#115 Posted : 21 February 2015 12:16:34
Thank you
Steve279021
#116 Posted : 14 March 2015 17:22:15
Pack 11 here now.
DaDokta
#117 Posted : 15 March 2015 17:40:22
I also received Pack 11 - hope i can work on it this evening!
Greetings,
Walter
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Steve279021
#118 Posted : 16 March 2015 08:26:17
You mean if the wife let's you!😁
#119 Posted : 16 March 2015 15:27:03
Just read back a few of your updates Steve, those hubs look amazing!
Although I have no interest in Formula 1 the more I see of these kits and the detail in them I keep thinking I should be adding one to my wants list
Steve279021
#120 Posted : 16 March 2015 21:25:32
Stage 35 done now. Gearbox started on with the 2 outer cases.
15 Pages «<45678>»
This page was generated in 0.368 seconds.
