7 Pages «<23456>»
tf64 HMS Victory x Section Build Diary Options
#61 Posted : 02 February 2015 21:39:07
Alan,
Thanks for turning the pages, my worry about the main Victory buckets is that you need about 21 to go across the poop deck, now I reckon they must be about 3mm tapering down to about 2mm! or do you think just to make 21 that fit across but out of scale ?
Trev
#62 Posted : 02 February 2015 21:44:17
Steve,
Thanks for looking and your comments, the problem I have is by habit I drift away and think up something new,and take ages to finish a build still more to follow soon.
Trev.
#63 Posted : 03 February 2015 14:57:42
tf64 wrote:
Jase,
Well I had a another go at making those buckets I found it better with Lime a softer wood to turn, I was wondering if you have had the time to try your new Proxxon lathe yet and what type of wood you find best?
Trev
Hi Trev,
I have had a play with bits of scrap etc. I do find softer wood easer to work as you would expect, but also easier to make a mess off. Harder wood gives you some advantage if you are doing tight shapes like banister spindles etc. I am of the opinion, at the moment, that if you can get away with lime do so.
As for your buckets I would shape them first then bore the centre after. Then I would paint and try and print the coat of arms glue on and varnish
#64 Posted : 03 February 2015 20:50:10
Jase thanks for the valued information I will give it a go and report back to you.
Trev
mark 2
#65 Posted : 04 February 2015 07:26:03
Hi Trev BigGrin .
Those buckets look great Cool, As Alan said they do look about the right size.
Great work from a great modeller.
Best regards.
#66 Posted : 04 February 2015 13:31:29
Trev
Dont recal if you had the detail packs for Victory or not, but i think i had a coat of arms pick in one of them that you could scale down and print. I will check tonight
J
#67 Posted : 11 February 2015 23:32:53
Hi Mark,
Thanks for looking and your comments Iv had a thought about those buckets and how to make them will post soon.
Trev.
#68 Posted : 11 February 2015 23:35:14
Hi Jase,
Not to sure what you mean about the Victory pack.
Trev
#69 Posted : 12 February 2015 14:07:46
tf64 wrote:
Hi Jase,
Trev
http://forum.model-space...aspx?g=posts&t=1091
follow the link. if you had these i am sure there was a pic supplied.
I am away at moment so cannot check the packs.
J
#70 Posted : 22 February 2015 19:49:51
UPDATE:
Victory Cross Section.
Completing the Orlop planking.
Today I completed the centre section of the Orlop decking,I found that I had to fit a false deck because when it came to cutting the planking it was so fragile it cracked, so the only way was to fit a false deck and stain the under side, the next job was to draw the outlines with a pencil using a new blade I marked over the pencil lines, I then drilled small holes around the markings and removed the wood with a knife and file.
Next try the mast and elm tree pump castings for position and adjust for misalignment all seemed to be ok.
Centre Section To be planked but I had to make a false deck to allow me to make small cuts without splitting the wood.
This picture shows centre section with the wood removed.
This Shows the Elm-tree-pump castings in place.
Elm-tree- Castings and main mast in place.
Next adding the frames to the pump well and painting white.
Thank you for having a look at my work more soon.
Regards to all,
Trev.
#71 Posted : 22 February 2015 20:45:31
That deck looks really nice. loving the build
#72 Posted : 22 February 2015 23:09:01
#73 Posted : 22 February 2015 23:53:32
Great work Trev, coming along a treat....Cool Cool
#74 Posted : 23 February 2015 22:47:14
Hi thank you for your valued comments ,
Jase, Steve ,Alan
Trev
#75 Posted : 24 February 2015 22:46:42
Hi Trevor.
Looking really superp. Look forward to seeing more of your cross section. IanCool Cool BigGrin
#76 Posted : 25 February 2015 20:02:05
Thanks Ian ,my thoughts are that to build a cross section before you attempt a main build ,will give you a good idea what's going on and have that hands on experience.
Thanks again
Trev.
#77 Posted : 25 February 2015 21:04:07
Like your thinking Trev and well done so far, looks great Cool
We'll be introducing a 12-month video build of the Victory very shortly BigGrin
#78 Posted : 25 February 2015 21:41:32
Hi Trev, BigGrin
That`s coming on a treat.
Cool Cool Cool Cool
#79 Posted : 08 March 2015 09:42:21
Hi Derek,
Thanks for looking and your support.
Trev
#80 Posted : 08 March 2015 10:17:30
UPDATE:
VICTORY CROSS SECTION.
080315.
Making Orlop Chests.
In this short update I am showing a few pictures of the Orlop chests which are custom made to fit between the riders. Also I will be making a few seaman's chests in a variety of styles and sizes, on these I will add the brass strip to make the metal bands for the lids.
Thank you for looking
Trev.
Guest (11)
7 Pages «<23456>»
