15 Pages «<23456>»
Graeme's U-96 build Options
#61 Posted : 26 February 2015 09:27:15
Funny, I was looking at the same site last night. I was thinking of removing the bolt and filling the hole with epoxy to retain some extra strength.
#62 Posted : 27 February 2015 21:29:07
I am almost 2/3rds the way through the vents of the second bow section but decided I needed some very small sanding sticks to tidy up the vents as they are too small for a needle file.
I took a couple of old etch brass frets 0.4mm thick and cut several suitable sections from them. I then glued these sections to the back of a couple of grades of silicon carbide paper (180 & 320 grade) using evo-stick serious glue which is waterproof. Once dry I cut around the brass to give me several small files approx 0.7mm thick which fit the vents perfectly and I will be able to use them wet to hopefully give me a better finish.
pemberg attached the following image(s):
daffy09
#63 Posted : 27 February 2015 23:17:53
What a brilliant idea mateBigGrin , was having the same problem myself, in fact I almost botched up the first 2 slots trying to use a modelling knife to cut away the drilled holes. This job is going to turn into a major exercise in patience and sore finger tipsBigGrin
Still it's going to make all the difference to the finished result. Well done.
Happy building
David
#64 Posted : 27 February 2015 23:49:44
Genius idea, great thinking Cool
#65 Posted : 28 February 2015 00:01:22
The simple ideas are always the best, nicely done and thanks for sharing....Cool Cool
DaDokta
#66 Posted : 28 February 2015 11:22:06
Brilliant idea, Graeme!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#67 Posted : 04 March 2015 09:35:49
Thanks for all the positive comments guys. Didn't get anything done over the weekend - she who must be obeyed decided we (me) needed to start decorating the kitchen Bored but thats life I suppose.
#68 Posted : 08 March 2015 14:56:30
Hi, finished the decorating so back to the build. I have removed the forward bolt and filled with 24Hr epoxy to prevent any problems when fitting the torpedo tubes later in the build.
The only fit problems I had with the plastic parts were with parts 66 & 67 which needed the shoulders on the enhancement cross bulkheads sanded down a bit as they were not deep enough (as David pointed out in his build).
The final photo shows the parts fitted but not glued as yet as I want to paint those forward bulkheads, which sit behind the now opened out vents, black once the epoxy has set.
daffy09
#69 Posted : 08 March 2015 15:50:12
Nice going Graeme, your 'opened up' ballasting vents look really good in situ.
Sorry you had the same problem with the issue #21 parts, I can only assume that it's down to that German company not producing the 'conversion ribs' to the correct tolerance to enable these parts to sit properly. All part of the fun hey!BigGrin, you got there in the end though! I'm sure the final result will be worth all the effort and I guess they'll be several more work around's before this part (torpedo room conversion) of the build is completed. Nice clean work. Well done
Happy building
David
#70 Posted : 08 March 2015 22:45:00
looking good enjoying your diary
DaDokta
#71 Posted : 09 March 2015 08:24:07
I like what i see, Graeme!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#72 Posted : 09 March 2015 10:36:29
Thanks for the positive comments guys. I am due more parts later this week and was going to leave gluing the current parts until then but on looking at what we get in the next few issues, on the german site
http://www.u96-bauen.de/vorschau/
which shows all the parts and consruction instructions up to issue 67 at the moment, none of upcoming parts continue on from the current ones.
Also, looking at the parts which come with issue 25 it looks as though part 64 will need modifying otherwise it will cover part of the open torpedo room. All fun and games.
#73 Posted : 10 March 2015 00:58:42
Hi Graeme.
Coming on a treat. Look forward to seeing more of your superp build IanCool Cool
#74 Posted : 10 March 2015 13:16:10
Hi Graeme, BigGrin
Coming on well, nice diary too. Cool
#75 Posted : 10 March 2015 16:04:56
Thanks for the kind comments guys.
#76 Posted : 22 March 2015 09:25:35
The forward bulkheads behind the vents have been painted black and the parts glued in place and given a preliminary fill and sand. All final prep will be done just prior to painting.
There is not really much to do with this months parts as the stern parts are not glued until later in the build and the forward parts I am leaving off just now to facilitate the fixing of the torpedo room parts later.
Most of the starboard forward part (part 64) will need to be cut away as it will cover the torpedo room cutout.
The second pic shows the forward and stern parts (stbd only) in place but not glued and the third pic the build as it actually is.
I must sat the whole structure is pretty solid now and is gaining weight rapidly.
#77 Posted : 22 March 2015 11:30:47
Looking good Graeme, getting better with every post.....Cool Cool
#78 Posted : 22 March 2015 11:51:18
Some excellant work you are doing.
It's really beginning to take shape now.
Hope the rest of your build goes well.
daffy09
#79 Posted : 22 March 2015 18:29:37
Lovely work Graeme, she really is coming along great now.
happy building
David
#80 Posted : 22 March 2015 23:46:23
Nice work Graham Cool
I cant get over how big these things are, looking forward to seeing this being more complete
15 Pages «<23456>»
This page was generated in 0.203 seconds.
