Electric toothbrush Options
Schnozzle
#1 Posted : 27 February 2015 23:34:20
Rank: Beginner Level 3
Turquoise Medal: Turquoise Medal for model making know-how contribution
Have any of you modified an old electric toothbrush to act as a sander???
I suspect this would be quite easy to achieve, and with replaceable heads, several different heads could be used for differing requirements.
Just a thought!
Eagle
#2 Posted : 27 February 2015 23:41:41
Red Medal: Red Medal
Yes! I have done this; and found it somewhat useful for small areas-the trick is finding a way to make sandpaper pieces interchangeable, maybe velcro would work? For now I use a white glue which is easy to apply and a remove.
Schnozzle
#3 Posted : 27 February 2015 23:51:09
Most electric sanders have velcro sanding pads, so super glueing the hooks to the toothbrush head would allow you to change the sandpaper with ease, after cutting to shape!
This page was generated in 0.084 seconds.
