4 Pages 123>»
Marsot Sky Drone Build Options
Marsot
#1 Posted : 03 March 2015 15:33:06
Stage 1 - Beginning the drone
I have started to build my drone and wanted to share it with you.
Looking at the Official Build Diary and the superb YouTube videos, togrther with the supplied instruction, there is sufficient advice on 'how to' build.
So my diary will be brief and usually contain 2 photos (1) The specific parts to use in the stage and (2) my completed stage.
I hope you find it interesting
______________________________________________________________________________________________
Building: Sky Drone, HMS Victory, Mary Rose
Wishlist: Spitfire
http://www.sotheran.com
Marsot
#2 Posted : 03 March 2015 15:39:12
Stage 2 - Adding the logo
Marsot attached the following image(s):
Wishlist: Spitfire
Marsot
#3 Posted : 03 March 2015 15:41:19
Stage 3 - The rotor arm hinge
Wishlist: Spitfire
Marsot
#4 Posted : 03 March 2015 15:42:55
Stage 4- The undercarriage
Please note a M2 x 12mm screw in photo should be a M2 x 6mm. Look carefully for it in the packaging.
Wishlist: Spitfire
Marsot
#5 Posted : 03 March 2015 15:47:47
Stage 4 - The undercarriage - continued
Wishlist: Spitfire
Marsot
#6 Posted : 03 March 2015 15:49:44
Stage 5 - The front rotor guard
Wishlist: Spitfire
Marsot
#7 Posted : 06 March 2015 14:04:20
Stage 6 - The blue LEDs for the first rotor arm
You will need the blue LED from Stage 2
Wishlist: Spitfire
Marsot
#8 Posted : 06 March 2015 14:06:02
Stage 7 - The second rotor joint
Wishlist: Spitfire
Marsot
#9 Posted : 06 March 2015 14:07:29
Stage 8 - the red LEDs for the second rotor arm
Wishlist: Spitfire
Marsot
#10 Posted : 06 March 2015 14:11:25
Stage 9 - The first anti-clockwise rotor
Place the black nut (for anti-clockwise rotor) into rotor blade and screw onto drive shaft supplied.
Wishlist: Spitfire
kenjara
#11 Posted : 07 March 2015 00:10:55
Nice to see another build diary up. Hope you are enjoying the build! I can't wait for pack 3!
Marsot
#12 Posted : 02 April 2015 16:09:28
Stage 10 & 11 - The front left rotor arm
Stage 10 was a checklist of completed stages so far and storage of a clockwise rotor for future use.
Wishlist: Spitfire
Marsot
#13 Posted : 02 April 2015 16:12:41
Stage 12 - Red LEDs for the rear left rotor arm
Wishlist: Spitfire
Marsot
#14 Posted : 02 April 2015 16:14:19
Stage 13 - The rear left motor
Wishlist: Spitfire
#15 Posted : 02 April 2015 20:33:07
#16 Posted : 02 April 2015 20:34:58
BigGrin Starting to come together now, should be a blast when she takes off for the 1st timeCool
#17 Posted : 02 April 2015 20:47:19
Hi Marsot,BigGrin
I`m not into this build, but looks like everything is going in the right direction.Cool
Keep up the good work and don`t forget, "should" you encounter any issues then just ask. There`s always someone here to help. BigGrin
Happy Building.
#18 Posted : 03 April 2015 00:02:18
Looks like you are making some great progress there Marsot. Look forward to seeing more... Cool Cool
Marsot
#19 Posted : 06 May 2015 17:58:07
Stage 14 - Straps for the battery case
Use the straps provided in Stage 11 with Chassis in Stage 14
Wishlist: Spitfire
Marsot
#20 Posted : 06 May 2015 18:03:49
Assembling the body
Under carriage bar from Stage 4 and Chassis from 14.
Wishlist: Spitfire
4 Pages 123>»
This page was generated in 4.432 seconds.
