Kudos to Customer Service Options
mwb
#1 Posted : 04 March 2015 02:22:25
While building the base I came across two cross threaded cap bolts (honest - I didn't cause it) and one of the threaded inserts would not take a cap bolt. Emailed customer service and ten days later the replacement pack was on the door step. Problem solved. Now that's service. Thank you Christina M.
This page was generated in 0.080 seconds.
