Issue 18 strip tapering Options
rjones
#1 Posted : 05 March 2015 20:07:27
Rank: Newbie
Hi everyone, long time lurker here, been collecting the issues for a long time now and was wary of doing the tapering described in issue 18 on the false keel.
Basically I didn't want to get it wrong but did anyone take the measurements of where to start tapering these strips,like it starts tapering at the start of a certain rib frame and comes to a point at a certain point? Sorry for this newbie question on an old issue but I'm afraid to do it wrong and mess up the whole model.
#2 Posted : 05 March 2015 20:17:45
Hi RJ, the subject of tapering planks has come up many times on the forum and I know when I started my first tapered plank I had the same thoughts as you.... where does it start and where does it finish and will I get it right Blink Blink .... Cool Cool ... You may find the following links of use to you to get a better understanding of what you are trying to achieve. Have a good look through and if you still have questions then do come back to me, am here to help if needed.... Cool Cool
http://forum.model-space...aspx?g=posts&t=6169
http://forum.model-space...aspx?g=posts&t=5669
It is difficult to say where the taper on your build should start and finish without seeing a pic of your build plus every build will be slightly different. However I think you will find it is not as difficult as it would first appear.... Good luck with it....Cool Cool
This page was generated in 1.105 seconds.
