5 Pages <1234>»
Sky Rider Drone Build.. Options
longblade
#21 Posted : 17 March 2015 15:01:08
Stage 12.Fitting the Red LEDs and the transparent cover to the rear left Rotor arm. The arm and the transparent cover from stage 8 plus 2 M2x6 screws from the same stage.Feed the long wires through to the end, and the short wires through to the end with the circular light cluster, connect the two plugs together. The new light strip is placed in the center with the holes lined up with those in the arm, the clear cover is placed over the top and screwed down with the afore mentioned screws..
longblade attached the following image(s):
#22 Posted : 17 March 2015 15:06:16
longblade
#23 Posted : 17 March 2015 15:12:06
Stage 13. The rear left motor. Required for this assembly, The drive unit from stage 11 and the washer and snap ring from the same stage. Insert the drive unit into the shaft casing, it will pull in quite powerfully as it has strong magnets. take the washer , and fit over the protruding shaft, followed by the snap ring. Use a small pair of flat nosed pliers as this cannot be done with the fingers. This completes the final stage from Pack 3.. It doesn't look like I have gotten very far as yet, maybe there is going to be a sudden rush of parts, I hope so as im quarter the way through, only 9 more packs to go......
longblade
#24 Posted : 17 March 2015 17:01:48
stevie_o wrote:
Nice workBigGrin Bet this ones going to be a lot of fun!
There,s not a lot to assembly, well not at the moment anyway. Should be great to fly with its various attributes...Bob.
kenjara
#25 Posted : 17 March 2015 20:56:29
Yeah pack 3 was a little light on work. Here's hoping for plenty to do on the next pack.
I'll admit I did have fun with the motor magnets though hehe.
longblade
#26 Posted : 25 April 2015 10:54:15
Well, Its Pack 4 time.
Stage 14.
The Chassis, and the fixing of the power pack belts..
longblade
#27 Posted : 25 April 2015 11:02:25
Stage 15.
contents, propeller CCW.
needed for this stage are the undercarriage (from stage 4) the chassis, having just attatched the straps,4 M3 x 12mm screws also (from stage 4) and 4 of the M3 nuts from the last stage.
The nuts need to be put into their respective holes, circular side up. The undercarriage leg now bolts to the chassis with the 4 M3x12mm socket head screws.
longblade
#28 Posted : 25 April 2015 11:06:39
Stage 16.
The first ESC, electronic speed controller.
Fix to the chassis for now with masking tape rolled into a loop, sticky side out..
longblade
#29 Posted : 25 April 2015 11:10:45
Stage 17.
Supplied parts for the roror arms. and the fixing of the red cover to the rear left arm. Ensure when fixing the cover that the wires are not pinched or damaged..
#30 Posted : 25 April 2015 11:24:50
Looks to be coming together nicely Longblade - bet you can't wait to have that first test flight?!Drool Cool
Difficult to view your pictures though as they are a bit large and need scrolling left and right to see it all - if you resize them to about 640 x 480 (Bulletin Board size), that'll be perfect? ThumpUp
Keep the updates coming, looking good. Cool
longblade
#31 Posted : 25 April 2015 11:34:38
Stage 18.
Parts with this stage, Blue LED light for front arm.
And a checklist of the parts that you should now have awaiting use..
Front left rotor arm and guard,(red)
Right side of body, with Pininfarina logo.
Rear left motor, rotor and arm.
Chassis, with undercarriage bolted to left side.
From stage 1, M5x16mm and M5 nut, for attatching arm to chassis. plus 4 M2x6mm screws.
From stage 3, 8 M2x12mm screws, two groups of 4, to secure the arm hinges to the body.
From stage7 one M5x16mm screw and one M5 nut,to secure arm to chassis.
From stage 10, Propeller 10x4.4 inch clockwise, for front left motor.
From stage 11, 34 M3x10mm screws, for motor and rear rotor guard.
From stage 14,3 M2x6mm. 3 M2x 12mm. 2 M3x12mm screws, and 4 M3nuts for the chassis..
From stage 15, Propeller 10x4.5 inch counter clockwise for front right motor.
From stage 17, 4 M3x10mm screws, for motor and front left rotor guard, back left rotor cover, ring, snap ring and spare grubscrew for front left motor, and, 3 M2x6mm screws.
And finaly from stage 18, Blue LED light for front right arm...
That makes the project one third complete, in the box there dosn,t seem to be a lot, but when listed its quite quite a bit. All these loose parts will be used up in due course, please keep safe....
longblade
#32 Posted : 24 May 2015 12:40:48
Pack 5 stage 19.
Part included, black rotor guard and black rotor guard support.
The part required for this stage are: The Back left?? rotor arm from stage 17. The back left rotor. 4 M3x 10mm screws from stage 17 + black rotor guard support from this stage.
Remove the circular LED cover from the back left ?? rotor arm, keep the screws till the end of this stage.
Pass the motor wires through the triangular hole in the arm (removing the red cover will help)
longblade
#33 Posted : 24 May 2015 12:50:54
Motor and guard support installed.
refit the pars removed.
Fit black cover from stage 17, CAUTION, do not pull or trap the wires, Store rear left arm??? till later. ( this arm will not fit in the rear left position on the chassis, as the locating pin/recess are on the wrong side).
longblade
#34 Posted : 24 May 2015 12:55:33
Stage 20. Parts supplied, Right undercarriage , 4 screws M3x 12mm.
assembly: 4 M3 nuts from stage 14 are fitted in the recesses as in the assembly of the left undercarriage.attatch the leg with the 4 M3x12 screws as with the first leg.
longblade
#35 Posted : 24 May 2015 13:07:54
Stage 21, Parts for this stage: The motor for front left arm.
Put the two motor parts together and fit washer and snap ring saved from stage 17.
Take the front left arm assembled in stage 11 and remove circular covers in the rear leg. Pass the three motor wires through the triangular hole. Caution, do not get heavy handed and damage the wiring..
Remove the RED rotor guard from its support. be careful that the clips are undamaged. Fit the guard support between the motor and the leg using 4 M3 x 12 screws from stage 17.
Replace the LED light plate and clear circular cover, thread the wires right through to the end of the leg,, Put away until needed at a later assembly stage.
longblade
#36 Posted : 24 May 2015 13:23:46
Before butting away for later attach the red cover, from stage 1,( all that time ago), with the three M2x6mm screws from stage 17..
#37 Posted : 24 May 2015 13:27:38
Coming along very nicely, really enjoying your build....Cool Cool .. Well done...
longblade
#38 Posted : 24 May 2015 18:15:01
Thank you Alan. A few problems along the way, but I think they will sort themselves out in due course.
#39 Posted : 20 June 2015 11:42:34
Hi Longblade,
All those parts to wire up looks a very exciting build to do and well done.
Trev.
longblade
#40 Posted : 21 June 2015 18:00:41
Pack 6, stage 23, this is the halfway point, don't know how they are going to get the rest in within the next 6 months, We shall see.
For this stage the red covered leg with the blue LEDs (Front left) assembled in stage 22 and the four M2x12mm screws from stage 3 and the M5 nut from the very first pack, stage 1 .And of course the chassis last worked on in stage 21... Time to fit the first of those legs?????Insert M5 nut in the socket, front left underside of the chassis, rounded side uppermost.
Thread the wires from the leg through the hole in the chassis, put the motor wires through the same hole, try not to kink, twis or pull said wires.
Using the 4 M2 screws, fit the leg to the chassis, tighten the screws with the screwdriver provided. move the arm into the horizontal posision and into the locking slot, ensuring the pin on the chassis engages with the recess on the arm..
5 Pages <1234>»
This page was generated in 1.961 seconds.
