gun ports Options
yorkieboy1
#1 Posted : 05 September 2010 09:55:32
Hi all
After much interesting discussion yestaday on the above I have found a new use for the magnifyer I dont know if anyone else has mentioned this but here goes and I hope it makes sense .Take off the magnifying glass section and in the bulldog grip place a pencil keep the hull in the jig and on a flat surface measure out where the bottom of the gun port will fall and using the mag stand as a waterline marker you can run it along and mark out where all the gun ports will fall measure up 12mm and repeat and you have the dimensions everything parrellel Hope this makes sense would be interested to hear other members views
mavrickandgoose
#2 Posted : 05 September 2010 10:06:03
Thats genius!!!! i spent all last night trying to figure out how to mark the water line on my HM Schooner Pickle, now i know how i will be doing it this afternoon!!! cheers steve
Dontshootme
#3 Posted : 05 September 2010 10:08:29
LOL Beat you to it...albeit as a waterline marker!!LOL http://forum.model-space...default.aspx?g=search#0|5
budgie
#4 Posted : 05 September 2010 10:36:22
BigGrin secure a pencil to appropriate length of wood even if u drop it, its still going to be correct height
mavrickandgoose
#5 Posted : 05 September 2010 10:47:33
that is what it says in the build instructions, but i cant get my hands on a block of wood at the moment, although i did get some funny looks when looking in a skip outside my building on camp for one!!
This page was generated in 0.762 seconds.
