 Rank: Pro Groups: Registered
Read lots of comments about double planking the Hull , Can any one tell me what veneer would they use ?? Oak ?? When veneering the hull you going to stick it on in thin strips like planking , if so how can you make the joints stand out , Would Linen thread be a good idea as suggested for planking the Decks ? Any advice would be appreciated . Regards and Happy Building . Malcolm
Maldbuild wrote:Read lots of comments about double planking the Hull , Can any one tell me what veneer would they use ?? Oak ?? When veneering the hull you going to stick it on in thin strips like planking , if so how can you make the joints stand out , Would Linen thread be a good idea as suggested for planking the Decks ? Any advice would be appreciated . Regards and Happy Building . Malcolm Hi and welcome to the forum The choice of veneer depends on personal taste, my guess is that those of us double planking will select a wood they feel looks best. Personally, I'm using Lime veneer, measuring 1 x 5. As for making the joins stand out, you might find that as the first planking (if you are double planking) will be sanded quite a bit, the veneer on top will need little if you get the first layer right. With a bit of oil/varnish etc they would probably stand out enough. However if you wanted to add a layer of thread, I guess you could leave a small gap between the veneer planking and then lay the thread into that? Maybe someone else can offer some more ideas! Tom
Thanks for your advice Tom, Will have to do some mock ups with the Veneer and see how the Joints show up ,Your comments are most helpful . Cheers Malcolm
Joined: 23/04/2010 Posts: 84 Points: 234 Location: Redruth
Second Planking is normally Walnut. 1x5 Built Billings Le Bayard Mamoli Golden Hind Corel Shenandoah In Progress AL King of the Mississippi Mantua HMY Britannia 1893/HMS Victory 1/98 Stopped Yet to start AL Zuiderzee Botter (Pre laser)Fun fun fun Constructo HMS Victory Caldercraft HMS Victory Deag HMS Victory
Cornwallray wrote:Second Planking is normally Walnut. 1x5 I'll be using walnut for the lower hull planking because its a great wood and looks really nice. The upper hull planking is a much lighter wood however, so lime matches the supplied wood pretty close Tom
Joined: 27/03/2010 Posts: 188 Points: 614 Location: Llandudno
Hi guys. I am still considering double planking am also going for the painted ship. Does it matter, in that case, which type of wood to use? Should I buy & fit before using the ones which DeAg supply or doeas it matter?
Thanks Bob
Boaz wrote:Hi guys. I am still considering double planking am also going for the painted ship. Does it matter, in that case, which type of wood to use? Should I buy & fit before using the ones which DeAg supply or doeas it matter?
Thanks Bob Hi Bob, If you are painting it then my guess is that it wouldn't matter as much. You might want to get some opinions from others on here as there are varying grains that may show through, so thats something for you to consider. Not sure if Deag are supplying a second layer of planking Regards, Tom
Thanks Tom. My next question was going to be where is the best place to get the extra planking. I'll ask around & see what the other guys reckon
Thanks again Bob
Joined: 18/03/2010 Posts: 121 Points: 359 Location: Waterlooville, Portsmouth. The home of HMS Victory.
Hi Matey!
Cornwall model boats have a huge range of everything. Illustrations on their web site are very good.
Paul wrote:Hi Matey!
Cornwall model boats have a huge range of everything. Illustrations on their web site are very good. Thanks Paul I will have a look at There web site , Thanks to everyone one for there response to this post Mald
Can't fault Cornwall model boats, absolutely brilliant range of items and very fast delivery
Tom
Probably a stupid Question but here goes . Approx how many strips in Walnut how many in Lime looking at pictures probably need mahogany as well . Any one got any idea what the whole model would take to second blank the hull ?? Comments would be appreciated .
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
Not sure how many but if you are buying you second planking from Cornwall Model Bosts they come in 1m strips and have most widths so you may be able to get an idea from working on that principle. Someone on here may be able to give a more exact answer. You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
thanks Riff raff tried to work it out , Might wait untill i get some of the plankng done before i order some for the double planking regards Mald
hi mauldbuild,your first question,ref. making the joins between the plank show,never came across a builder wanting them to show???? every plank is different,it will show,unless you are very unlucky and very skillfull you will never need to caulk the outer planking,now question2,how many plank to cover the boat? can you measure? run a rule round the hull, the planks are 1mtr.long or 1/2mtr. long.divide the hull that you measured by 5 and you got the answer. by the wy my wife just told me off i'M a grumpy old man,no offence matey it's the way I tell'm Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Hi Karl ........... yes Mate I do have a ruler , secondly I can certainly measure , Thought this forum was to help fellow builders , Just thought one of my fellow builders might have an idea of were the different colours are on the hull and how many APPROX strips it takes to achieve the bandings. Maybe I should just rely on my own judgement . As far as jointing is concerned the hull not really expecting to see joints, deck yes . Thanks Grumpy old man ...Its the way I tell them NO Offence intended
mald matey,my last reply came out all wrong,their was supposidly humour in it,but the way you asked your questions I had no idea it concerned the banding on the hull,also I misunderstood 'bout the caulking,there are many strings on here referring to this.look up index in search and you will find all your answers,anyway sorry bout the misunderstanding, blimey 16 letters in that last word,going to have a lie down now. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Hi.....
My current build is the HMS Surprise and the complete hull is approx 160 planks. The hull is longer than victory aswell. So if that helps in what you are looking for. Close ups of the banding on the Victory look like its two 5mm planks wide. And 4 on the lower band.
If you look on this build you may get an idea of the planking arrangements and how many on the banding.. http://www.facebook.com/...5688845092&view=all
Thanks Chris.....On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Thanks for the comment Magpie ,will study the picture a bit more carefully . Hi Karl Not a problem mate being following your comments and build on the forum from day One . No offence taken . Keep up the great build Regards Mald
