Screenshots Options
ALW
#1 Posted : 24 March 2015 08:48:02
Hello all
How do I attach screenshots?
Thank you.
#2 Posted : 24 March 2015 08:51:56
Would have to be done in the forum of as you would a photo.
ALW
#3 Posted : 24 March 2015 11:07:03
Hi, I've started a thread but can't see where the option to attach
a picture is.
I thought this was the forum?
ALW
#4 Posted : 24 March 2015 11:10:59
Hello
Looks like I found out how to do it!
As you can see I have just completed pack 2 but the fuselage sides or at least one of them looks 'bowed'. All the formers are at 90 degrees, will this cause a problem for future construction?
Thank you
#5 Posted : 24 March 2015 11:13:47
a picture is.
Hi Alan, BigGrin
The attach picture button appears at the top of your page. It`s the one with the sun over two mountains.
You will also need to reduce the size of your pics to a smaller size to fit the forum.
Best size is 660 x 400 pixels.
Hope this helps.
ALW
#6 Posted : 24 March 2015 11:15:49
Thanks Derek
I must have a mental block when it comes to attaching photos on a forum!
Never mind I hope what I have posted makes sense!
Thanks again
#7 Posted : 24 March 2015 11:16:40
Indeed it will cause big problems as the skin panels will not align and you'll also have a permanent banana shape.
You need to disassemble and reset, or if the side was warped before you assembled, try to steam out the warp after disassembly or get a replacement.
ALW
#8 Posted : 24 March 2015 11:22:21
Thank you
I thought that might be the case.
This page was generated in 0.131 seconds.
