Official Harley-Davidson Fat Boy Build Diary Stages 44-49 Options
#1 Posted : 28 March 2015 11:55:39
Pack 14 contains stages 44-46
Stage 44 contains the rear suspension.
The components of stage 44 should be carefully stored in a bag labeled with the stage number for future use.
#2 Posted : 28 March 2015 11:57:09
Stage 45 contains the fuel tank cover and screws.
You will also need the fuel tank from stage 21 for this part.
Take the cover and with the cut out facing downwards line it up with the four screw holes then turn the assembly over and fix in position using the four 'N' type screws.
Store any unused parts in a bag labeled with the stage number for future use.
#3 Posted : 28 March 2015 11:59:20
Stage 46 contains the rear fender and screws.
The components of stage 46 should be carefully stored in a bag labeled with the stage number for future use.
#4 Posted : 13 April 2015 19:55:53
Pack 15 contains stages 47-50
Stage 47 contains the brake pedal,support,foot rest,spring,Harley Davidson fender plaque and screw.
For this stage you will need the rear fender from stage 46 and the rear left indicator and bracket from stage 48.
Line up the indicator with the left hand bracket making sure the projection alignes with the cut out on the bracket and push gently home. Next insert the cable plug through the square hole in the fender once this is done line up the three studs on the bracket with the holes on the fender and push gently home until its fully seated in place.
Store the assembled and unused parts safely in a bag labeled with the stage number for future use.
#5 Posted : 13 April 2015 19:59:57
Stage 48 contains the rear left indicator and bracket.
The left bracket was assembled in stage 47 for this stage you will need the fender assembly from stage 47 and the right rear indicator bracket from stage 50.
The right rear indicator and bracket are fitted in the same way as described in stage 47.
#6 Posted : 13 April 2015 20:03:46
Stage 49 contains the rear brake calliper with fitted cover and the radiator.
For this stage you will need the right swingarm from stage 22 and a 'C' type screw.
Take the calliper and line it up with the two holes on the frame once it is in position use a 'C' type screw to fix it in place.
This page was generated in 0.336 seconds.
