Looks interesting Ken, and a bit of a challenge too  Good luck with the gilding! Steve
Hi ken good luck with the guiding look forward to seeing your progress Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi all as I said I've never guilded before should I paint the blue first then guild over that or should I guild the part first then paint the blue over it, and if painting is first should I use gloss paint guild over that then matt coat the blue. Ken's the name modeling's the game.
Looks like a great kit Ken, looking forward to seeing this come together. Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Hi Ken. Lovely looking ship there! If by guilding you mean actual gold leaf then you'd have to guild the entire part first by painting it with a coat of 'size' which dries to a sticky finish, the gold leaf is then placed over the sticky part and gently pushed down into the crevices with a very soft brush (sable usually). Then you'd have to paint the blue background in between the figures. If you mean a gold coloured paint then I'd paint the whole thing in a good matt blue (after a suitable primer) and then paint in the gold figures on top. I've never used the gold leaf myself apart from a very small amount at Art College all those years ago! Hope that helps! Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Yep real gold leaf so even if I ruin it it will still be worth 50 quid melted down(assuming I use all the gold leaf) (which being a novice is more than probable) thanks for the info (there is a soft brush with the kit so I recon that's what it's for) Ken's the name modeling's the game.
Hi Ken, Have looked at this kit several times on ebay. A brave move with the gold leaf and that`s from someone who`s tried it and got some reasonable results with no training. (Self taught) I bought my gold leaf kits off ebay at a very reasonable price, to use on my Sots build. Some advise from my attempts is as follows: A: Make sure the parts are clean and grease free. B: If you have a spray gun, a light grey primer (thin coat). A plastic primer from a car parts shop in a spray can will do. C: A deep maroon oil paint (as thin a coat as possible). This forms a backing colour to give the gold depth and if you have minor cracks in the gold, they don`t show up as much. D: Now apply the "Size". E: I found it easier to use smaller pieces of leaf. Even if the gold overlaps when tapped down with the brush, when fully dried if you very gently use your soft brush and brush over the gold, any overlap brushes off and can be used for gap filling if needed. Hope this helps and good luck with the build. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Interesting looking kit there Ken, can you read French
Thanks for the Guilding info, very useful, nope can't read french but like to look at the pretty pictures. Ken's the name modeling's the game.
Hi Ken, That looks like a great start on the guilding. Well done, looking forward to more of the same.  Don`t personally think you need a wash as the gold forms it`s own shadow spots and would be a real shame to lose all that "BLING". Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Guilding looks spot on and well done for deciding to go down this route.... Regards Alan
well I've got to the first problem with guilding, getting a crisp line, mind you I still yhink it looks good    Ken's the name modeling's the game.
Gilding looks fantastic Ken  Perhaps the straight edges could be masked first before applying the gold? Just a suggestion as I've never done it before. Steve
stevie_o wrote:Gilding looks fantastic Ken  Perhaps the straight edges could be masked first before applying the gold? Just a suggestion as I've never done it before. Steve You`re right to an extent Steve. Two possibilities: 1, The gold will only stick where the size is applied, or spreads, so finer painting of the size or using less of it may help. or 2, As Steve suggests mask the line to make sure the size goes only where you want, remove the mask and then apply the gold. If you apply the gold with the mask in place, you may end up with masking tape, size and gold all stuck together and a right old mess. Hope this helps. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thanks Derek, Steve, great tips which I shall use on the straight bits but round the filigree bits the engraving is so fine it would be impossible, have to give that some thought and see what I can come up with. Ken's the name modeling's the game.
Hi Ken, Looking good, Just how long is that thing, it looks huge. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
It is 33 inches I just hope I do it justice, even my missus says it's pretty, and I've barely started. Ken's the name modeling's the game.
